Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 01-12-2003, 10:37 PM   #1 (permalink)
Question Pulling it all together...
Here goes, about to purchase a TOSH 32ZP38 + TOSH 330E + Sky +. I have no idea about cables apart from QED and IXOS seem to by pretty good makes. Can anyone advise on the way to go to pull the whole lot together?
Fallguy is offline   Reply With Quote
Old 03-12-2003, 6:17 PM   #2 (permalink)
Lagavulin's Avatar
Location: A little piece of sanity in an insane world...
Thanks: Gave 41, Got 154
Hi Fallguy,
Yeah, I'd advise using QED cabling (mine is 100% QED throughout my entire system), but Ixos are usually a bit cheaper.
I'd buy some good Component cables [QED's around £100 ]for hooking up the DVD player with a decent co-axial Digital cable [QED's about £40/50] for the players audio into the TV. Then get a fully wired Scart [QED's Squart goes for £40/50] for your Sky box. I know it sounds expensive but a good set of these cables will give you the very best out of your investment and they'll probably last you a lifetime.
HTH mate,
All the best,
LAGAVULIN
Sony 52Z4500 | Oppo BDP-83 [MR] | Denon AVR-2310 | Monitor Audio BR5's/BRLCR & MJ Acoustics Ref150-MkII Sub [7.1] | Xbox 360 Jasper (512mb) | PS3 (Orig. 60GB) | Harmony One
Lagavulin is offline   Reply With Quote
Old 04-12-2003, 9:48 AM   #3 (permalink)
RedBull's Avatar
Thanks: Gave 0, Got 4
Originally posted by Lagavulin
I'd buy some good Component cables for hooking up the DVD player with a decent co-axial Digital cable
I've gone for Ixos - simply because I've always used them in the past and thought I'd continue with my HC setup.
They are slightly cheaper - Especially judging by the component price that Lagavulin gave - I paid £55 for my Ixos components. I used Toslink IXOS digital interconnects, and that was around £45.
Hope that helps!
RedBull is offline   Reply With Quote
Old 04-12-2003, 2:01 PM   #4 (permalink)
Thanks guys for the posts, I am thinking of the following combination:
Component video.....IXOS XHV 704
Digital co-ax..............QED Qunex P75
Digital Optical............QED Qunex OT
Scart.........................IXOS XHT 611
I suppose the question really is would paying alot more for one or more of the above give a SIGNIFICANT improvement? Welcome your thoughts
Old 04-12-2003, 6:15 PM   #5 (permalink)
Lagavulin's Avatar
Hi again Fallguy,
Not a bad combo at all - IMHO
Well, I'm all for investing (and that's what it is - an investment for the future) some good cash in good cables, but you've gotta be sensible. For instance, your telly [the ZP38] is a FANTASTIC piece of kit (although I had to return mine ), but the DVD player, although good, is a far cry from 'high-end'. So the Component and Scart is quite a good choice from the players POV, but if you upgraded in the future to a better player (e.g. around £600-900), then it might be worth your while in getting some better stuff. But for now, I reckon your above combo will be fine
Hope all goes well - and enjoy!
Best wishes,
LAGAVULIN
Old 04-12-2003, 6:34 PM   #6 (permalink)
Hi Lagavulin,
Many thanks for your advice...appreciated! Taking delivery on Mon so I will be very interested to see if any of the problems experienced by other members of this forum show on my system. Fingers crossed
Old 04-12-2003, 6:35 PM   #7 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
I wouldnt spend that much on cables for that set up!!!
Profigold or Thor would be fine cant remeber model No of the top of my head but if you want good cheap cables for YUV and Digital audio the see Mark Grant in power buys forum, Custom cables (now thats POSH)
Gold plated RGB scart for Sky+ andan optical cable.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 05-12-2003, 4:23 PM   #8 (permalink)
Lagavulin's Avatar
Hi Lagavulin,
You're more than welcome mate.
Taking delivery on Mon so I will be very interested to see if any of the problems experienced by other members of this forum show on my system...
I hope not, and I wouldn't worry too much ...the ZP38 is a mighty fine telly when behaving itself. I only experienced probs when playing back DVD's in Prog. Scan (pure prog. straight out of the DVD player I mean), so since you don't have a prog. scan DVD player - yet - all should be well
Happy viewing Fallguy and let us know how things go,
Regards,
LAGAVULIN
pulling
