3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Lifeless: Zombie TV series Matthew Attoe On Television 4 15-07-2009 11:27 AM
New TV - £1000 to Spend Akah Which LCD TV Should I Buy? 12 07-07-2009 5:59 PM
3G and 3GS case / protection thread davemulheran iPhone Discussions 1055 07-07-2009 2:59 PM
Breaking news: Panasonic to offer Freeview HD TV’s next year! The News Bot Home Cinema and Tech News 19 05-07-2009 12:03 AM
Display Sony Walkman NWZ-S639F image on TV? Dunno48 Portable Music (MP3, iPod etc.) 1 03-07-2009 7:04 PM
Old 02-07-2009, 6:28 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Matsui TV showing PROTECTED
I got a Matsui 27" CRT TV on Freecycle.
It's been working fine but today my toddler switched it off and my wife guessed at the codes (incorrectly).
It is now flashing "PROTECTED" and switches onto standby.
Is this something I can fix?
Needless to say, I do not have a manual!
Bernie_the_Bolt is offline   Reply With Quote
Old 02-07-2009, 6:44 PM   #2 (permalink)
t1m103's Avatar
Thanks: Gave 120, Got 150
Re: Matsui TV showing PROTECTED
hi mate try this taken off another site when someone had similar problems >
Stuck in Protect Mode: First attempt to guess the four digit code by using any random numbers. On your third unsuccessful try the unit will stop asking for pin numbers on screen and go into the "protect mode" Within 5 seconds hold in the volume down on the TV at the same time as pushing the Number "7" on the remote handset. The set should then come on in the "unprotected mode" & you can see & alter the pin code in the correct menu if you desire. BTW if you have made three incorrect guess, this set has to be left unplugged for sometime B4 it allows you to guess again! It will go into standby within 10 seconds after "protect" is flashed on the screen.
Matsui Repair tips database, Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
PIONEER KURO PDP-428XD(ISF CALIBRATED),DENON AVR-1910,MORDAUNT SHORT 908I'S/902I'S/905I,ELTAX SUB,60GB PS3,XBOX360,FAT PSP,OPPO 981HD,SKYHD(PACE),MARK GRANT CABLES.
t1m103 is online now   Reply With Quote
Bernie_the_Bolt (02-07-2009)
Old 02-07-2009, 6:57 PM   #3 (permalink)
Thanks for this.
Unfortunately this TV does not seem to have a volume button!
Unless I am dense and cannot find the secret flap!
Old 02-07-2009, 7:01 PM   #4 (permalink)
t1m103's Avatar
Originally Posted by Bernie_the_Bolt View Post
Thanks for this.
whats the model number?.
Old 02-07-2009, 7:05 PM   #5 (permalink)
Best I can tell from the back is 28 WN04
Old 03-07-2009, 7:05 AM   #6 (permalink)
Thanks for all the help.
Turns out that all I have to do is to leave the set unplugged for a while (overnight in my case but it may be less as a minimum required) and it goes back to the beginning.
So problem solved, what a relief!!!
matsui, protected, showing
