Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Harmony Remote Multiregion DVD Hack for Panasonic, Pioneer & Sony Blu-ray's Pt.5 AV Junkie Blu-ray Players 1004 26-07-2009 4:41 PM
Panasonic TH-P42V10 and TH-P50V10 Owners Thread - Part 1 hybridtheory Plasma Televisions 1012 23-07-2009 4:28 PM
Panasonic G10 Owners Thread - Part 2 JulieBell Plasma Televisions 999 19-07-2009 4:39 PM
Panasonic Viera TX-P42S10B @ £799 from John Lewis kinboshi Plasma Televisions 1 02-07-2009 4:51 PM
Panasonic HDC-HS300 zorba11 Camcorders and Video Editing 15 02-07-2009 1:53 PM
Old 02-07-2009, 2:36 PM   #1 (permalink)
Panasonic TX32PS12 Screen Fault
Hi Guys,
I have decided to post here as this forum seems to be the Best!!
Our TV has just gone caput! - could be something to do with the hot weather??? Or it could be nothing to do with that just age, it's about 6 years old and has been well used.
Anyway essentially 75% of the screen just isn't working and remains black, I've tried all the AV channels and they're all the same so it's not likely a problem with any particular input. I cannot see the blue setup options either which also suggests to me the problem lies with the screen
The portion of the screen that isn't working is basically everything below the top 3 inches of the screen - I have always thought that a tube going bad would result in the screen gradually reducing in size like the end of the twilight zone!! But I'm often taken in by urban legends and stuff so it may be utter nonsense.
Hope you can offer something in the way of a diagnosis and/or possible prognosis.
Many thanks in anticipation.
Azreal_ is offline   Reply With Quote
Old 02-07-2009, 3:12 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 859
Re: Panasonic TX32PS12 Screen Fault
You have a frame output fault by the sounds of your description.
It could be something as simple as a dry joint or a failed component in the frame (vertical) output circuit...it could also be a corrupt eeprom IC...either way...unless your handy with a soldering iron and are used to handling electronic components you'd be best advised to call on the services of a local TV repairman.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
fault, panasonic, screen, tx32ps12
