Re: Phillips 36pw9527 Crooked Picture
[QUOTE=Bigelboe;9773945]Hi all,
I have recently purchased one of the above TV's that's a couple of years old. It seems to be a pretty good TV except the picture is tilted, on the left side of the screen the picture is probably 10mm higher than on the right, so its very noticable. If I zoom in so the picture is slightly cropped it is not a problem, but if there are any black lines or bars on the bottom of the picture it's very obvious.
I have searched this forum and found how to get into the service menu, and have been all through this trying every parameter and have found none that adjusts what I need. Is it possible to adjust this at all in software or is it a hardware adjustment or something?
Any help would be greatly appreciated.
If i am correct you can tilt the picture from the service menu. If you search it you will find it.
I have the 32pw9617 and i remember the tint setting.
Try one more time and you be lacky next time.
Nick
service menu code 062596i
