Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 11-11-2003, 6:14 PM   #1 (permalink)
k0rcha
Posts: n/a
Unhappy Help new TV...
I recently recieved a toshiba 32z33b television and the picture is slightly fuzzy. I have mainly used it for games so far but the picture on regular TV is not so great either. I'm not bothered about the TV part (my aerial connection isnt very good) mostly the games, but do you think this could be down to poor cables? My PS2 scart cable is RGB but was only a cheap one, so maybe it would be a good idea to buy a better quality one. If anyone can recommend any then I would be most grateful. I havent got my DVD player yet and am kind of worried that the picture will be bad even when i get that .
If anyone could spare a moment to help me I'd be very grateful.
Thanks,
Chris.
Old 11-11-2003, 6:34 PM   #2 (permalink)
Marv's Avatar
Thanks: Gave 3, Got 31
Yeah get a Blaze Monster cable.
All post © Marv 2004
PSN: Marvdogger
Marv's DvD's
Marv is offline   Reply With Quote
Old 11-11-2003, 6:54 PM   #3 (permalink)
k0rcha
Posts: n/a
Hate to be a nag, but could you perhaps tell me where to buy one?
Will dixons/comet/game have them?
Thanks again,
Chris
Old 11-11-2003, 8:09 PM   #4 (permalink)
Thanks: Gave 27, Got 145
Have a look at ixos .co.uk they do a very good ps2 scart lead.
peahead is offline   Reply With Quote
Old 11-11-2003, 9:52 PM   #5 (permalink)
k0rcha
Posts: n/a
Thanks a lot guys, I just hope this fixes it otherwise i have another 'dud' telly Im not so lucky with em...
My theory is that its a bigger TV so you can see the imperfections more but im still not sure though.
Thanks again
Chris
Old 11-11-2003, 10:00 PM   #6 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
dont you have YUV component connections on your telly, if so might want to invest in a Prog scan PS2 (if TV will cope)
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 11-11-2003, 10:12 PM   #7 (permalink)
Thanks again
Chris
Just out of interest how far away from the TV are you sitting? With a 32" you should be at least 9 foot away to get the best picture. Maybe thats not helping?
lewden is offline   Reply With Quote
Old 11-11-2003, 10:12 PM   #8 (permalink)
k0rcha
Posts: n/a
Nooo just scart and composite (the yellow plug i think Always get confused). I couldnt afford a component one
Perhaps I am sitting too close aswell :D
Thanks for all the help people, you've been great.
Now to get me one of those ixos cables (that look really expensive!)
Chris
Old 11-11-2003, 10:46 PM   #9 (permalink)
Assured Advertiser
you could just get the offical Sony RGB one (assuming you have set PS2 to RGB )
Old 11-11-2003, 11:14 PM   #10 (permalink)
Hi k0rcha
As a matter of interest, where did you get your 32z33B? I ordered one from empiredirect way back in September but haven’t heard from them yet. I phoned Toshiba last week and they said they would be available in early December. Mind you, I’m a bit worried about the picture quality now (should have tried before I buyed but it did seem like a good offer)…
By the way, www.fillyourboots.com do a nice range of IXOS cables at discount prices. I don’t think they list a PS2 lead but it may be worth sending them an email.
Anyway if/when I get mine I’ll let you know what the PQ is like.
Cheers,
Chris B
Skull Cowboy is offline   Reply With Quote
Old 11-11-2003, 11:58 PM   #11 (permalink)
k0rcha
Posts: n/a
I ordered mine from www.tvandvideodirect.com and they delivered within 4 days. I think im paranoid of TV's now because of all the problems i had before so i wouldnt get too worried. Thanks for the link aswell, ill look into that definately!
Good luck with your order. Theres nothing worse than not knowing when its gonna come
P.S Thanks again dragon.
Old 20-02-2004, 5:26 PM   #12 (permalink)
Thanks: Gave 0, Got 19
Hi k0rcha what is this TV like now picture wise please.
Regards Trevor
tulloch2003 is offline   Reply With Quote
