Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 08-11-2003, 12:09 PM   #1 (permalink)
Thanks: Gave 2, Got 1
Question 36" CRT choices?
Hi folks,
My first posting to this board - although I've been 'lurking' for a while! I've got a Panasonic 32" 100Hz set that's around 3 years old (not sure of the model number). I'm wondering whether it's worth upgrading to a 36"?
I watch Sky Digital & DVD (no terrestrial or VHS), and use an XBox. Although my current DVD doesnt support progressive scan, I would like this feature (PAL & NTSC) for when I upgrade the DVD.
I was interested by the Panasonic PD30, but then read the number of problems with it!
The things I don't like with my current set:
Only 1 RGB socket
Colour convergence problems in corners
Ghosting on av inputs
slight "dirty screen" effect
The new Toshibas look nice, but I understand there are some JVC & Hitachi sets coming out. I don't particularly like Sony as a brand, but would consider them if that was the recommendation.
Anyway, enough rambling - looking forward to your comments!
Regards,
Kev
mistuk is offline   Reply With Quote
Old 08-11-2003, 12:26 PM   #2 (permalink)
RoadhawR
Posts: n/a
I'm in exactly the same position. I've had my Tosh 32MW7DB a while now. It was repaired by a bunch of local cowboys recently and has not been the same since, though every one whose seen it, comments on a great picture, i'm convinced it's not as good as it once was.
I've been looking at the Tosh 36ZP38 because i like the thin bezel and Unbeatable are doing it with DVD and Video player!
Afaik it has 3 scarts but only 2 are RGB, grrrr, i can't believe there are still no sets with lots, 4-5, RGB scarts yet. I mean they add sod all to price of the set surely. Luckily though i have a 4 way switch box which is RGB capable.
I don't mind Sony TV's, I had a 28 before this one and i almost got a Sony 32. I like the Sony remote controls. They seem quicker than the Tosh which is awful, slow and oversized.
I haven't read any reviews of the Tosh yet so i would welcome some comments also.
Old 09-11-2003, 2:57 PM   #3 (permalink)
Have just brought a Sony 36 FS 76 and i think its excellent. Got a good deal and service from the local Sony centre. The picture from Sky and from my Panasonic DMR-E100H is great, i love it
john hannam is offline   Reply With Quote
Old 09-11-2003, 3:32 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,331
36PD30 has prog scan and YUV inputs for your Xbox or DVD as well as 2 RGB scarts! Excellent TV and slim design so although it is huge it wont deystroy your room!
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
choices, crt
