Re: SONY KD28DX 200U Repair
You don't say how soon after the water spillage it was switched on.
If it was just a small amount of water the usual procedure is just to wait until it has evaporated before applying power...this process can be speeded up by playing a hairdryer on a low heat setting on the affected area of the circuit board...with the set unplugged of course.
If this doesn't work there's probably a short-circuited component or two...you would need to call on the services of a TV repairman and get an estimate for repair.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
