Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 07-11-2003, 1:35 PM   #1 (permalink)
Tosh 220-Sony 36FS76 no RGB-signal
I have connected the scart from the DVD to the TV according to manuals but I don´t get the RGB-signal. What can I do to receive the RGB-signal, is it a setting in a menu on the TV?
Any help much apreciated!!
Daniel.A
daniel.a is offline   Reply With Quote
Old 07-11-2003, 3:00 PM   #2 (permalink)
k0rcha
Posts: n/a
There might be a setting in the DVD's menu to set the output to RGB. If not then maybe your cable is not so good? I dont know.
Hope that helps,
Chris
Old 07-11-2003, 8:08 PM   #3 (permalink)
jelly's Avatar
Thanks: Gave 9, Got 8
i dont get a signal either check your rgb menu the rgb setting will only be accesable if a rgb signal is being recieved by the tv
SAGEM HD-45F, SKY+, TOSHIBA HD E1,YAMAHA RXSL-80, X-BOX 360
jelly is offline   Reply With Quote
Old 07-11-2003, 9:16 PM   #4 (permalink)
zingo
Posts: n/a
do you have a scart with 20 pins? RGB-signal needs this kind of scart to work.
Good luck!
Old 08-11-2003, 8:06 AM   #5 (permalink)
Pug72's Avatar
Thanks: Gave 30, Got 75
I have this set until this morning(it's going back due to contrast flickering and I hate the picture quality).
You can check if the signal is RGB by going into the menu and selecting the RGB set-up(or something like that).
If you can't change the settings such as moving the screen, you aren't inputting a RGB signal.
I suspect you are though as the AV icons don't display the 3 dots in the square for RGB signals, don't no why.
Pug72 is offline   Reply With Quote
Old 08-11-2003, 3:06 PM   #6 (permalink)
Thanks for the input all of
Thanks for your input everyone!
The cable has 20 pins so it shouldnt be the problem. I cant move the picture in the RGB setting so that would indicate i dont have the RGB signal then. I´ll check the DVD-menus then and see what happens.
Old 09-11-2003, 12:24 AM   #7 (permalink)
Super Moderator
Thanks: Gave 289, Got 161
While not wishing to wee on your fire, RGB only leads have,iirc, only 6 terminals connected.
http://www.shopfox.co.uk/hi-fi/1307.htm
Opinions given are my own and are not associated with avforums.
lynx is offline   Reply With Quote
Old 09-11-2003, 12:29 AM   #8 (permalink)
Super Moderator
daniel.a, on your remote handset, key the setup button (½ way down on the left), choose RGB from the video out select option.Now ensure that an RGB enabled socket is used on the Sony and toggle through the choices till you come to the RGB sign.You should be able to view an RGB PAL display now.
Scart 1&2 on your tv accept an RGB input.
220sony, 36fs76, rgbsignal, tosh
