23-09-2006, 8:31 PM
#1 (permalink)
Thanks: Gave 18, Got 6
Room Seeks CRT
Plan is to get a 9" crt and an 8 to 9 foot fixed (I think) screen
The beams in the attached are roughly 3m apart and 2.1 meters up.
Suggestions and thoughts on mounting between the beams gratefully received
Chris
24-09-2006, 7:02 AM
#2 (permalink)
Thanks: Gave 33, Got 18
Re: Room Seeks CRT
Could you floor mount or does it have to be ceiling mount?
JVC HD100,NEC XR5,Toshiba HD-EP35,Sony S550,JVC30K D-VHS,TagAV32 BP192,Tag DVD32FLR,Rotel RMB-1095+Rotel RB-1080,B&W 604,LCR6,DS6,SVS PC-Ultra
24-09-2006, 7:29 AM
#3 (permalink)
Re: Room Seeks CRT
Hi Baggy,
I could floor mount but thought ceiling mounted would be preferable as it would mean less keystone correction, if this is the right terminology.
Chris
24-09-2006, 8:09 AM
#4 (permalink)
Thanks: Gave 493, Got 261
Re: Room Seeks CRT
That is an older style roof and so the actual roof beams should be strong enough to mount from.
Thats the beams that follow the roof line and not the two horizontal seen in the picture.
Floor mounted usually has the issue that the best seat in the house is exactly where the PJ sits
Floor mounting can also mean shorter cables, thats always a good thing.
Floor mounted does keep the PJ at a cooler level. And if a DIY job easy to install.
But For most Ceiling mounting is the answer.
Mad Home Cinema
24-09-2006, 8:15 AM
#5 (permalink)
Re: Room Seeks CRT
Chris
Sort of.......
Many projectors can be set up in 3 different ways
Ceiling mounted
Floor Mounted
or Mounted On Axis
First two i think explain themselves.
Third is usually a rear screen projection setup the PJ site in the middle of the screen (on axis)
Depending on your position of the screen relative to the PJ will alter your required Keystone.
It is possible to have the same keystone for floor and Ceiling mounted - the PJ just needs to be the same distance above or below the screen for each mounting method.
Keystone is used to correct the left and right side geometry, this keystone adjustment allows you to make the sides vertical, high end machines will allow seperate control of left and right side.
Mad Home Cinema
24-09-2006, 8:45 AM
#6 (permalink)
Re: Room Seeks CRT
As Mad said with a floor mount the PJ occupies the prime seat but is easier for a DIY install.
What PJ are you getting?
24-09-2006, 8:55 AM
#7 (permalink)
Re: Room Seeks CRT
Thanks for the explanation, I thought I needed to learn a bit more.
What I was meaning is that if I floor mount then there would be a steeper angle to contend with than if I ceiling mount. That said there probably isn't much in it.
I aslo figured it would want my seat!
Depending on what is available but I'm aiming for one like yours, a 1209 and of course I want it now!
Other issues to contend with are getting it up the stairs which I will measure and photograph later for comment by those in the know. That said, the sub on the LHS is a REL Studio III and weighs 200lbs!
Chris
24-09-2006, 8:56 AM
#8 (permalink)
Re: Room Seeks CRT
Here's a set up I had at my last place in a similar style room.
http://uk.photos.yahoo.com/baggy123uk
24-09-2006, 9:02 AM
#9 (permalink)
Re: Room Seeks CRT
Very nice Baggy,
I had been considering floormount as it would mean I could run cable under the floor, both from the PC and for power.
I dont plan to move from here any time soon and as you can see the room is dying for a bt of kit rationalisation and some thought on design.
The system has grown over the last 15 years and nothing has been done vis a vis cosmetic appearance (racks, cabling etc) so there is plenty of scope!
Ceiling mount seems somehow better in the long run, if only because of the hot seat, but I'm coming at it with an open mind!
Chris
24-09-2006, 9:04 AM
#10 (permalink)
Re: Room Seeks CRT
Other issues to contend with are getting it up the stairs which I will measure and photograph later for comment by those in the know. That said, the sub on the RHS is a REL Studio III and weighs 200lbs!
Chris
At my last place we used the loft room and that meant carrying the Marquee 8001 I had then up two flights of stairs. An extreme effort but most definately worth it.
24-09-2006, 9:12 AM
#11 (permalink)
Re: Room Seeks CRT
If you're thinking of a 1209 use the LENS program (Mad has put a link in the FAQ thread) to calculate distances and height of the screen in relation to it.
You appear to have limited height ,so take that into consideration.
24-09-2006, 9:26 AM
#12 (permalink)
Re: Room Seeks CRT
Have you visited fellow forum member Meep's website.
It's a nice looking loft room.
Search under his user name for a link to his website.
24-09-2006, 9:40 AM
#13 (permalink)
Re: Room Seeks CRT
If you're thinking of a 1209 use the LENS program (Mad has put a link in the FAQ thread) to calculate distances and height of the screen in relation to it..
Will do. Ta
Not sure what you mean by limited height. The beams that run into the shot are 2.1m off the ground and 3 m apart. The apex of the roof is 3.5 or 4 m up.
At my last place we used the loft room and that meant carrying the Marquee 8001 I had then up two flights of stairs. An extreme effort but most definately worth it..
Exactly the same scenario here. Yorkshire stone 1904 semi with attic room up two flights, second one through a narrow door.
Alternative though was to excavate cellar but SWMBO baulked at the £50k cost, sissy!
I have now, thanks I will read t this afternoon.
Chris
24-09-2006, 9:47 AM
#14 (permalink)
Re: Room Seeks CRT
When I said "limited height", I was thinking you were going to put joists between those two beams to hang a projector from and they are only 2.1m high.
That being your height limitation.
Sorry if I misinterpreted.
24-09-2006, 9:55 AM
#15 (permalink)
Re: Room Seeks CRT
Meeps HT can be found here
http://www.meedja.ie/ht/
I found me another one  thanks for the mention of this one Baggy....
I will add it to the Members CRT list.....
Baggy - Can I add a link to your old system too ?
Im trying to build up our ist of CRT HT, but we have many shy members here........
Mad Home Cinema
