AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > CRT Projectors
LinkBack Thread Tools Display Modes
Old 13-09-2006, 8:43 AM   #1 (permalink)
Thanks: Gave 1, Got 7
Sony D50 questions
Could anyone please tell me what tubes I should be looking for if I wanted to replace the D50 tubes?
I've read on past threads that the ideal resolution is 800x600 for this crt, which is fine for dvd disc's etc, but my htpc display looks a little fuzzy and wondered if I should be using a different resolution for htpc.
According to the manual this crt can do 1280 x 1024 what would be the problem of running at this?
cheers
S
garyc is offline
Old 13-09-2006, 10:28 AM   #2 (permalink)
ilkand's Avatar
Thanks: Gave 15, Got 2
Re: Sony D50 questions
Apparantly, that resolution is very hard to set up unless your tubes are newish. It looks too soft. 800 600 is always quoted, although 1080i is supposed to be possible.
andy
ilkand is offline
Old 14-09-2006, 9:44 PM   #3 (permalink)
morksbeanbag's Avatar
Thanks: Gave 30, Got 37
The tube type you are after is the P14LKJ03. Very hard to get hold of apparently.
Alot of projectors can accept a high res signal, but showing it in full isn't so easy.
My 1272 can show a 1600x1200 according to the specs but i feed it 576p from my dvd player and its great. No scan lines at all. If you want to fully resolve an image at 1280x1024 with it looking razor sharp, you need a better pj. Otherwise, use a lower resolution.
Yamaha DSP-Z9, Sony DVP-S9000ES, Sony BDP-S1E, Yamaha NS-1000M, Yamaha NS-635 (presence), B&W CDM CNT,Mission 77ds x 4, Sony SA-WX900 Sub
Sony VPL-VW12HT on 82" Stewart Greyhawk
morksbeanbag is offline
Old 15-09-2006, 7:48 PM   #4 (permalink)
thankyou for the tube info.
wasn't intending to goto the max stated resolution just wondered just how far up towards it you could go, maybe slightly higher than the 800x600 I'm currently using.
garyc is offline
d50, questions, sony
Refbacks are On
Thread Thread Starter Forum Replies Last Post
sony d50 focus help scartlead CRT Projectors 5 02-07-2006 5:51 PM
Sony D50 at 1080i? ilkand CRT Projectors 0 31-05-2006 4:52 PM
Sony VPH D50 QM tony cts General Chat 0 27-01-2006 9:25 AM
Sony D50 409hrs what's it worth Greg Lancaster CRT Projectors 4 03-09-2005 11:40 AM
Service screen on sony D50 Greg Lancaster CRT Projectors 3 24-08-2005 11:32 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
