AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > CRT Projectors
LinkBack Thread Tools Display Modes
Old 09-09-2006, 6:28 AM   #1 (permalink)
Thanks: Gave 0, Got 6
My experience with the DVI > RGBHV modules.
With all the talks about HDCP, I decided to purchase John’s BG-DVI module. After several weeks of waiting, I was informed that the list is closed, and that John will not supply the modules anymore.
At this point I decided to purchase Moome’s DVI EXT BOX. While waiting for the arriving of Moome’s EXT BOX , I read about Greg’s port3 modification. Since I felt frustrated because I couldn’t put my hand on John’s BG-DVI module and after reading some reviews about Moome’s EXT BOX , I have decided to order Greg’s port3 modification .
I was curios to see the benefits of replacing my 15 meter long RG6 Belden cables, with a DVI cable.
Eventually, the two modules arrived at the same time. With Greg’s module, the story was a bit longer. At the beginning, I received v 2. The picture quality was not acceptable, due to heavy ringing. Port3 was sent back for modifications to v3. with v3 the picture quality was better, but still not good enough. Greg asked me to send back the port3, and this time, port5 too, to upgrade to v4s.
In the pictures below, you can see the two new DVI modules compared to the analogue way that perform with exceptional picture quality, based on HTPC -> ATI Radeon 9700 Pro + MP-1 mod.
Equipment that is used:
1.The PJ: Barco Graphics 1209s.
2.The Screen: Da-lite 4 x 3 (2.40 x 1.80 meter).
3.The Camera: Cannon G5, using tripod, distance from the screen - about 0.75 meter.
4.Source 1 : HTPC/ ATI Radeon 9700 Pro + MP-1 mod.> Belden 1694 RG6 cables + King BNC and the DVI output
5.Source 2 : HTPC /Nvidia 7900GT > DVI output .
6.The DVI Cables: A short DVI cable inside the PJ and a Ophit fiber/optic 15 meter cable.
7,Moome’s DVI EXT BOX .
8.Greg’s port3 V4s.
Note: I’m not sure about your experience with taking pictures using a digital camera, it’s very difficult to achieve good results. The actual sharpness of the picture on the screen is much much better then the posted pictures.
1.The analogue way - ATI Radeon 9700 Pro + MP1 -> Belden 1694 Cables + King BNC Connectors -> PJ
Picture details : 1440 X 1080@50 Hz, Screen @ 4X3.
2.Gerg’s port3 v4s module.
Picture details : 1440 X 1080@50 Hz, Screen @ 4X3 ,ATI Video card
Now it’s with the Nvidia 7900GT - we can see the scan lines in the Red better than in the ATI.
Picture details : 1920 X 1080@50 Hz, Screen @ 4X3
3. If you remember the thread at the AVS “What is the best CRT Projector out there”
There was used the RESOLUT.BMP in order to show the PJ capabilities to resolve 1080P So I took a few pictures using the RESOLUT.BMP as a windows background :
This picture was posted in that thread # 719:
http://www.avsforum.com/avs-vb/showt...&page=24&pp=30
Picture details : 1920 X 1080@50 Hz, Screen @ 16X9 ATI + MP-1 mod.
Picture details : 1440 X 1080@50 Hz, Screen @ 4X3 ,ATI + Greg’s v4s
Picture details : 1440 X 1080@50 Hz, Screen @ 16X9 ,ATI + Greg’s v4s
Picture details : 1920 X 1080@50 Hz, Screen @ 16X9 ,Nvidia + Greg’s v4s
This picture is done using Moome’s DVI EXT BOX, the actual sharpness is more sharper than the picture you see.
4. This is the first Greg’s Port 3( V2 ) received with the ringing problem, that was corrected with v4s:
Finally, I am happy to say that with the new modifications, I hope that my Barco PJ will continue to serve me for many years ahead.
Rittberg is offline
crispybig (13-09-2006), MadMrH (13-09-2006)
Old 12-09-2006, 1:55 PM   #2 (permalink)
Thanks: Gave 3, Got 5
Re: My experience with the DVI > RGBHV modules.
I've looking to get the DVI board for my 1209s. What other mods did you have done as well?
Thanks.
acave is offline
Old 13-09-2006, 5:35 AM   #3 (permalink)
Besides port 3 Greg v4s mod. I Installed a short DVI cable inside the 1209s and connected the HTPC => to the PJ's short DVI cable using an Ophit 15 meter long fiber/optic cable.
Rittberg is offline
Old 13-09-2006, 6:18 PM   #4 (permalink)
crispybig's Avatar
Thanks: Gave 10, Got 7
That was interesting and useful Rittberg - thanks for making the effort.
crispybig is offline
Old 13-09-2006, 7:15 PM   #5 (permalink)
Thanks for the reply. Other than on test patterns and text how much of an improvement in PQ are you getting?
thanks
Gary
acave is offline
Old 14-09-2006, 3:49 AM   #6 (permalink)
If you take a look to the Nvidia 7900GT => port3 v4s picture (Picture details : 1920 X 1080@50 Hz, Screen @ 4X3) you can see that this combination produced a sharper picture . In addition, now I have two high quality Inputs - port 3 with an excellent PQ handling DVI/HDCP and a modified port 5.
Rittberg is offline
Old 14-09-2006, 10:56 AM   #7 (permalink)
Alaric's Avatar
Thanks: Gave 4, Got 43
Hi There,
I guess the big Q is how much and which do you think is worth it ???
I'm also curious at how close to the back of the PJ this makes cables as i am almost touching my back wall, so even a few cm's makes a difference !
Ta,
Lee
My Way Over the top LOTR based Home Cinema
Curently For Sale: Nothing
Alaric is offline
>, dvi, experience, modules, rgbhv
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic TX32LXD52 - experience of PC input via DVI-HDMI? dnwill LCD Televisions 33 09-06-2006 9:30 AM
DVI experience... monotone Interconnects, Speaker Cables and Switches 3 10-10-2005 1:02 PM
'F/S: Various Memory Modules' shay0 Archive : Completed Business and Expired Threads 14 25-03-2005 2:27 PM
Hitachi 42PD5xxx, DVI and Mac mini experience lintonmac Plasma Televisions 4 08-03-2005 8:25 AM
DVI versus RGBHV ispra CRT Projectors 1 24-01-2005 10:10 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
