Thumbnails - click for bigger picture. Descriptions further down page.
Number 19: Hoisting - Follow the link to the ANIMATED GIFF:
http://www.cosaw.f2s.com/resized/500.gif
Not been frequenting the forums much recently - been busy. Here are some of the things I've been up to. A big Thank-you to all those who gave input through the forums in answer to my queries on this project. This is my first install. Not everything is completely finished yet but thought it time to post some pics. My objective was to make this a one man job and still keep the procedure safe. Yes I could have called on friends and used brute force but I prefer jobs I can handle completely by myself just in case I have to! Its a bit more of a challenge as well.
I went the Unistrut route and the pj can slide front to back and be moved up and down. The reason I did this was that the Barco lens prog doesn't doesn't accomodate data for my HD6-C lenses so I didn't know throw distances exactly. I did a partial floor setup beforehand - next time I'd do a full floor setup to get thorw and drop and then take up the floorboards upstairs and hang from inside the ceiling space. All that being said I'm quite happy with the way its turned out.
The big problem with using the unistrut turned out to be that the area of ceiling I needed to use was in no way level. There was a big bow in the plasterboard front to back and there was no way the strut would fit flush to the ceiling. I corrected this by using a piece of MDF board temporarily hung from the ceiling on four screws and then leveled with a gap left at the back. I then filled the gap with expandable foam filler. So that the filler didn't stick to the ceiling I bluetacked tinfoil over the ceiling. If we come to move and take the pj down the foam filler should come away cleanly without having to chisel it off the ceiling and ruin the plasterwork.
A brief description of whats going on in the pics going left to right and top to bottom:
1) Find the joists - I used a studfinder purely to test how good they are I then checked joist positions from the floorbard nails upstairs before drilling holes to find the joist edges. As I say I wanted to test the studfinder but I wasn't gonna rely on a stud finder when suspending around 60Kg above my head. The studfinder was of little help, I think you need a completely flat surface when using these and having a woodchip covered ceiling the studfinder was useless. I penciled everything on and worked out where coach screws would go and then transfered all my measurements to the mdf sheet which had the useful secondary function of being my template. You'll see I had to cut some coving out to get to the 4th joist. To find the centre-line I used the arc drawing method that Chris Frost recently detailed and it really does work a treat.
2) Plaster the holes up then paint. Leave holes which would carry string from above to hoist the 18mm piece of MDF.
3) Stick tin foil to the ceiling to stop expandable foam filler permanently welding itself to the ceiling creating more mess when I come to take the pj down.
4) Some paper backing for the now pre-drilled template and ceiling leveler. Just for completeness.
5) Hoist from above with 3 pieces of sting (there is a piece at the rear thats harder to see).
6) A view of the gap the foil the paper and the leveling screws. The gap was much smaller than this once leveld up with a spirit level. Then fill with expandable foam filler - DONT get this on your hands like I did - it takes weeks to get off - literally. Use rubber gloves and eye protection.
7) Strut up, 8 x 6" M10 coach screws, 2 in each joist - probalby overkill but better safe than sorry. Pilot hole 8mm, (7mm would have been better) for the threaded part of the coach screw. I then opened up the end of the pilot with a 10mm hole for the smooth shank part of the M10 coach screw to save putting a splitting force on the joists.
8) Another view of number 7 but showing cables better - 5bnc to vga, mouse, keyboard, power cable. My htpc is gonna be upstairs you see, its cheap ugly and noiser than my projector. I don't mind nipping upstairs when I want to change a dvd. Strut also has some more special metals primer on where I churned up the paint job with my socket set when screwing in the coach screws.
9) Chanel nuts with extra back nuts for locking and araldite metal style glue for extra security. I'd probably leave the glue off if I did it again - it gave way in a few places when tightening fixings at ceiling level and isn't really neccesary. I was gonna use nylon lined locking nuts all round but after messing with a few found they take ages to wind up and down the threaded rod and make adjustment more difficult and time consuming.
10) Washers glued in place to accuately guide the threaded rod through. See next step to see with rod removed.
11) Rod removed once glue set and guide holes are now centered. Paint job looks a bit iffy but now its on the ceiling it looks fine.
12) Everything hung.
13) Another view of number 12.
14) Pj on the floor front.
15) Pj on the floor back.
16) Chanel nut with threaded eyelet, shackel and chain. I used a "Quick Link" (1 on each chain) to stop the chain running back through once I'd hoisted a corner further. I replaced each link with a 5th spare link once I'd pulled the chain through on the corner I was working on. That chain would then have two quick links on it - one holding the weight of the projector and one redundant to take off and use on the next corner.
17) Chain shackled to strut which in turn is bolted to the pj.
18) Enough for another day pj goes to bed. You can see the holes I drilled in the case for g2 and electronic focus.
19) For the hoisting process click this link (
http://www.cosaw.f2s.com/resized/500.gif) to see the ANIMATED GIF which is just over 1 meg. As you can see lenses are removed and all the boards with heavy heatsinks have been taken out.
20, 21, 22, 23, 24, 25) Shots of it up. Needs its little door on to cover the lens adjustment bay. The expandable foam layer between ceiling and mdf also needs some tidying up. I quickly went over it with some white paint but intend to put some sort of beading round it in the future.
The work continues. My screen is up and I'm watching dvds now. Pj is mostly tweaked. If I do any more bits and pieces (which I am sure to) I'll probably add to this post with further pictures and stuff.
