intergrated graphics,possible to add seperate graphics card?
Old 28-12-2006, 12:00 PM   #1
brethy's Avatar
3,463, Level: 13
Points: 3,463, Level: 13 Points: 3,463, Level: 13 Points: 3,463, Level: 13
Thanks: Gave 2, Got 6
hi guys i've been looking at a computer which seems a great package apart from the fact it has a 950 intergrated graphics,is it poosible to add a sepeerate graphics card to make the pc more suitable?
Old 28-12-2006, 12:12 PM   #2
5,023, Level: 16
Points: 5,023, Level: 16 Points: 5,023, Level: 16 Points: 5,023, Level: 16
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 13, Got 71
Re: intergrated graphics,possible to add seperate graphics card?
As long as it has an AGP or PCIe slot. If it's a cheap Dell, it won't. Look at the specs of the PC if you see one of the above you are in luck.
TT
Old 28-12-2006, 12:13 PM   #3
stratagem
Posts: n/a
Also check the power supply rating, often if it's built down to a price it will fall over when you start to add graphics, more drives etc.
