Audio problem when joining 2 avi files
Old 10-02-2006, 1:40 PM   #1
suttonsboot's Avatar
4,629, Level: 16
Points: 4,629, Level: 16 Points: 4,629, Level: 16 Points: 4,629, Level: 16
Thanks: Gave 5, Got 1
The 2 files I'm trying to join won't work because of a problem with the 2 pieces seeming to have different audio on each one. Any ideas???
Old 11-02-2006, 4:06 PM   #2
5,891, Level: 18
Points: 5,891, Level: 18 Points: 5,891, Level: 18 Points: 5,891, Level: 18
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 214, Got 202
You could try converting the files to use the same audio type using a package like VirtualDub. It allows you to encode the sound steam of an Avi using any codec and sample frequency you choose (assuming you have the necessary codecs installed).
In addition Vitualdub will probably also allow you to join the files directly. It can re-encode the sound, without touching the video. I think you need to choose "Full Processing" for the audio, and "Direct Stream" for the video.
suttonsboot (11-02-2006)
Old 11-02-2006, 9:26 PM   #3
4,629, Level: 16
In the end I just used Nero to convert both files onto the one dvd it's got 2 chapters on it but it plays straight through. Only crap thing was the 7 1/2 hours to convert
Old 11-02-2006, 10:57 PM   #4
Uridium's Avatar
33,222, Level: 44
Points: 33,222, Level: 44 Points: 33,222, Level: 44 Points: 33,222, Level: 44
Activity: 24.6%
Activity: 24.6% Activity: 24.6% Activity: 24.6%
Thanks: Gave 527, Got 1,810
7 1/2 hours!!! what is it a 486?!?
