Advent System Restore
Old 25-01-2006, 4:34 PM   #1
Melkor's Avatar
Thanks: Gave 10, Got 8
Well i'm trying to reformat my PC and yet my desktop, an Advent 3316, will not boot from my Advent System Recovery Disk. I am fortunate to have two and i'm placing one in both drives and also seperately and it will not boot from the drive. Any advice on how I can fix this?
Old 25-01-2006, 4:38 PM   #2
Uridium's Avatar
Thanks: Gave 556, Got 1,869
When the machine boots up go into the BIOS (normally Delete/F2/F12 or similar) and change the boot order so that your PC boots from the CD drive before the hard disk
Old 25-01-2006, 4:40 PM   #3
Melkor's Avatar
Done that already, set CD to boot first - still nothing
Old 25-01-2006, 4:46 PM   #4
Uridium's Avatar
It should come up with a prompt saying "Hit any key to boot from CD-Rom".if you miss this it will still boot from the HD
If it isn't doing this recheck that the boot order change you made has been saved in the BIOS
Old 25-01-2006, 4:53 PM   #5
Melkor's Avatar
I have, still not responding at all :/
Old 25-01-2006, 4:57 PM   #6
Uridium's Avatar
Most advent PC's do come with a pair of restore discs.
Disc 1 bootable, Disc 2 second part of restore
You sure they are two discs the same not a Disc1 & Disc2, with Disc1 being the bootable one?
Old 25-01-2006, 5:03 PM   #7
Melkor's Avatar
Tried both disks in both drives. Really dont know what else to try
Old 25-01-2006, 5:09 PM   #8
Ayub's Avatar
Thanks: Gave 715, Got 524
are you using the restore disk or the recovery disk. Advents come with two. One has the main o/s and the other has all the drivers for the boards etc.
Old 25-01-2006, 5:10 PM   #9
Ayub's Avatar
stick the idsk in the first rom/ and them do it again. Also itmay be worth cleaning the disk.
Old 25-01-2006, 5:24 PM   #10
Melkor's Avatar
Im using the System Restore disk and yeah ive cleaned em
Old 25-01-2006, 5:27 PM   #11
Ayub's Avatar
Old 25-01-2006, 5:28 PM   #12
Ayub's Avatar
try booting only from cd rom an dnot h/d etc disable them if not fdisk it and then run the advent disk.
Old 25-01-2006, 5:29 PM   #13
Melkor's Avatar
Done that
Old 25-01-2006, 5:31 PM   #14
Ayub's Avatar
format it then run the disk that works 8/10 times.
Old 25-01-2006, 6:00 PM   #15
Melkor's Avatar
how do i format it?
Old 25-01-2006, 10:39 PM   #16
Uridium's Avatar
Wouldn't bother with the format, have never EVER known a formatted hard disk make any difference to whether your PC will boot from a CD or not! (and I install XP about 20 times in an average week!)
Sounds like your restore CD is not bootable for some reason. either this or your BIOS still hasn't picked up the boot order change.
Do you see the prompt when it asks you to press a key to boot from CD?
Next thing I'd do if I was you is to "Borrow" an XP cd from a friend and see if your machine boots from this, then install XP using the OEM sticker off the side of your case.
Could always try your "bootable" restore cd in a friends PC as well.
Old 25-01-2006, 10:41 PM   #17
Uridium's Avatar
Just had another thought.
If you are using a USB keyboard you will need to find and enable the option in the BIOS for "USB Keyboard support"
Other wise the keyboard will only work in the BIOS POST screen and will not respond on the next screen when the "Press any key to boot from CD" prompt comes up.
Old 25-01-2006, 11:23 PM   #18
Melkor's Avatar
I am using a USB Keyboard, but im not getting any message prompts at all. It seems i'll have to try and get hold of a XP disk or something because im not getting anywhere fast at the moment.
Old 25-01-2006, 11:34 PM   #19
Uridium's Avatar
It's possible that your BIOS may not give you the "press to boot from CD prompt".
Make sure "USB keyboard support" is enabled in the BIOS and remove everything other than your CD drive from the boot devices list.
Failing that it will probably have to be a borrowed XP disk next
Old 26-01-2006, 8:56 AM   #20
Melkor's Avatar
still nothing, i guess ill find an xp disk somehow
Old 26-01-2006, 11:43 AM   #21
I had problems with the Advent discs few years ago. I contacted them and they made sure I had all the relevant serial numbers so that they could send out the latest version of the discs. Could be worth trying them if you think the discs are the problem.
Old 27-01-2006, 4:16 PM   #22
Melkor's Avatar
Got an XP disk and its still not working - I guess its the CD drives. Is there any other way I can reformat system that doesnt include the drives?
