Originally Posted by fliegenaffe I was contemplating getting a Corsair H80 liquid cooler |
Doesn't make any sense on an i5, for the same cost as the CPU and cooler you could get an i7 with stock cooler which even at normal frequencies often comes pretty close or overtakes the overclocked i5:
Intel Ivy Bridge Core i5 3570K & Core i7 3770K Review - Processing Performance - Cinebench
And there's plenty of overclocking headroom on the stock cooler.
You don't seem to have decided on your priorities yet, are you looking at overclocking to a view that it might offer better value for money or do you just fancy it as a cool feature that it's worth paying a little extra for?
Originally Posted by fliegenaffe If you don't mind me asking,what intel chip would you recommend that I buy? Bearing in mind that I'm on a budget,the Phenom is about £80 on Amazon,whereas the i5 2500k is £165 |
You can get an i3-2120 from Amazon for under £90
