| Re: Laptop to PC using vga-dvi-i converter - HELP! Quote:
Originally Posted by jack2221991 I originally tried to do this by using a dvi-i to component (RCA) cable, only to find that the output from my laptop was dvi-d, so instead used a vga-dvi-i adapter, then using the same cable to connect to the tv. I am getting a "no signal" reading on my hdtv and am unsure as to what could be causing the problem. | DVI-D is a digital only connection
DVI-I is an analogue & digital connection
VGA is an analogue only connection.
Therefore you can not connect a DVI-D device to a VGA device without hardware conversion of the signal.
Mark.
__________________ Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200 |
