dos boot cd with ntfs reader?
Old 20-10-2008, 12:37 PM   #1
Joe Pineapples's Avatar
15,949, Level: 30
Points: 15,949, Level: 30 Points: 15,949, Level: 30 Points: 15,949, Level: 30
Activity: 23.5%
Activity: 23.5% Activity: 23.5% Activity: 23.5%
Thanks: Gave 218, Got 204
Has anyone created a dos boot cd, with an ntfs reader included (to mount and read ntfs partitions), and willing to share?. I've been trying to find one and going round in circles.
thanks
joe
Old 20-10-2008, 3:06 PM   #2
Scotty's Avatar
8,618, Level: 22
Points: 8,618, Level: 22 Points: 8,618, Level: 22 Points: 8,618, Level: 22
Thanks: Gave 7, Got 423
Re: dos boot cd with ntfs reader?
Originally Posted by Joe Pineapples View Post
thanks
joe
Not sure what your trying to do, but this should cover most options
Old 20-10-2008, 3:15 PM   #3
Illustrious Member
Singh400's Avatar
32,612, Level: 44
Points: 32,612, Level: 44 Points: 32,612, Level: 44 Points: 32,612, Level: 44
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 900, Got 2,125
What is it you are trying to do Joe?
Old 20-10-2008, 3:51 PM   #4
15,949, Level: 30
Activity: 23.5%
Yeah, seen that, but not sure it woul suit my purpose (see below)
Basically i have a laptop with a corrupted copy of XP on it (wont boot into windows, even in safe mode). There is no cd with it, but there is a genuine cd key label on the underside. However, from experience i know that this cd key is not always the one used when the windows image was installed, especially with a lot of the larger brand names. So i managed to find a dos based cd keyfinder, but the partitions are ntfs, and so i needed something to be able to mount and make those recognisable in dos - hence the boot cd.
its actually irrelevant now, for this particular job, as i found out that a repair install wasent an option - as it turns out, the windows was more corrupted than i thought. But it would be handy to have the boot cd for the future.
Old 20-10-2008, 6:03 PM   #5
Illustrious Member
Singh400's Avatar
32,612, Level: 44
Activity: 23.1%
IIRC BartPE allows you interact and loads custom programs on it. Might be worth a shot mate.
Joe Pineapples (20-10-2008)
