Access 2007 help
Old 25-01-2012, 11:09 AM   #1
Thanks: Gave 5, Got 1
Access 2007 help
I have access 2007, I have got a database with one form being a yes/no answer. I want to make it so if the answer is yes the row is green, if the answer is no the row colour is red. HOw can I do this.
Old 04-03-2012, 10:32 PM   #2
Thanks: Gave 20, Got 6
Did you get this sorted should be simple via a little VBA
