Windows 7 - Annoying UK / US Language problem. UK spelling doesn't work.
Old 05-05-2010, 2:12 PM   #1
Master Yoda's Avatar
Thanks: Gave 19, Got 41
Hoping someone can shed some light on this...
I have Windows 7 Ultimate with all the updates installed. The language installed and setup is for the UK - UK English (I have nothing set to US language or spelling in any of the settings anywhere). Despite this, everything in Windows (whether it be when I'm using email or word etc) keeps spelling everything to US and not UK english. This is actually extremely annoying as it keeps showing me that I've spelt things incorrectly when I haven't and it's messing my mind up. Only US words are in the dictionary and not the UK versions of the same words.
This seems to be a large bug in Windows 7 and I don't know how to fix it... I don't even have US language installed as an option so why on earth is it using US spelling?? UK English / UK keyboard is all I have installed and is the default language selected.
Old 05-05-2010, 2:20 PM   #2
Curly99's Avatar
Thanks: Gave 772, Got 1,887
Are you sure that "Location" and "System Locale" are set to "United Kingdom" in the Region and Language settings? Can you change the default language in browser, office apps...etc.
Old 05-05-2010, 2:32 PM   #3
The 'location' in Region and Language is set to 'UK' - I just double checked. Everything is on UK and UK English...
There is no option to change the language in Word or other apps... I just had a look.
This must be affecting loads of other people too??
Old 05-05-2010, 2:52 PM   #4
Thanks: Gave 4, Got 39
Oh yes there is
Which version of Office are you using?
Old 05-05-2010, 2:57 PM   #5
Curly99's Avatar
did a google for the problem and not a lot came up...probably need to find a windows guide to follow and change the setting to another language local (preferably one that is English based) reboot then change back to UK setting/locale...etc see if that works....doesn't windows use the IE or outlook dictionary as a default spell checker?
Old 05-05-2010, 10:08 PM   #6
Illustrious Mumbler
Mr Incredible's Avatar
Thanks: Gave 2,748, Got 6,694
Word 2003 - change Word default UK language spell check
Word 2007......
Master Yoda (06-05-2010)
Old 06-05-2010, 12:40 AM   #7
Thanks for the links - I managed to get UK english working in Word using your link for Word 2003 (I'm using Office XP). It only worked for me after trying it several times.
After doing a bit more messing around with Windows Live mail, I also managed to get that to work. I found it had UK english installed, but for some reason wasn't defaulting to it (just like Word).
I think this is a bit odd with Windows 7 - With Windows XP, if you set the language in the control panel, everything then follows suit (which is what you would expect). It appears that setting the language to UK English and the location to UK in Windows 7 control panel doesn't appear to do anything, as every application still defaults to US English (even though US english isn't even installed on my computer according to the Windows 7 control panel??).
Anyway - thanks for the responses guys. Just glad it's now sorted.
