| Re: creative soundworks speakers on av receiver
As long as the speaker resistance is more than the minimum stated in the receiver manual then this will be fine (although you may have to cut off the connectors at the ends of the speaker leads).
To check the resistance, however, you are going to have to open up one of the speakers (unless the creative manual says anything about it). On my creative 4.1 speakers there were 4 screws on the back. Simply remove them, and you should get inside the case. Look at the metal rear of the actual speaker driver, and there should be the resistance rating.
Unfortunately you will probably find they are 4Ohms (mine were).
I recommend you don't use them if they are 4ohms, as you may permanently damage the amp.
If they are higher than 4 ohms, then you still need to be careful - these are 6W speakers, and you're receiver is capable of 140W!
You should be able to plug the powered sub into the line out from the receiver.
