If you have a smartphone then remote control using that is popular these days.
Bluetooth has a standard audio/video remote control profile (AVRCP) and I believe most default bluetooth drivers support this so you may find that any bluetooth remote control will work and it doesn't have to be a PC specific one. I don't have any experience with that though, so try it first or do a bit more research before committing.
Alternatively, just install macro software and set up some of the keyboard buttons to double as volume buttons, I do this myself and have AltGr+Up/Down/End as Volume Up/Down/Mute.
