dbpoweramp
Old 11-05-2012, 8:33 AM   #1
mikedelvaux's Avatar
Thanks: Gave 15, Got 3
dbpoweramp
Hi everyone.
I'm just in the process of ripping my cds to a hard drive, in doing so I'm using dbpoweramp.
it rips the cds just fine with the album art being displayed during ripping.
the problem is once ripped the album art has dissappeared when you look in
the music folders, is there a way to keep the album art.
Thanks in advance.
Mike.
Old 11-05-2012, 1:06 PM   #2
Thanks: Gave 8, Got 38
I tend to use a two-stage process - perform the initial rip with dbPowerAmp CD ripper (to FLAC) and then fettle the tracks names, album art etc using the "Tag & Rename" app. It's not as convenient but gives you a chance to have a good look at the tracks and art and create playlist files because quite often there are spelling mistakes etc in the default stuff that's downloaded from gracenote and the like.
Old 11-05-2012, 2:12 PM   #3
ukbootlegs's Avatar
Thanks: Gave 195, Got 271
I do the same as loader using the same s/w
it makes it easier for loading compilation cd's onto an ipod too
Old 12-05-2012, 10:27 PM   #4
Thanks chaps guess I'll have to do the same.
Mike
