Cannot Copy Error - Help Please
Old 10-07-2011, 11:49 AM   #1
Thanks: Gave 608, Got 14
I am running Vista Home Premium.
I have been happily copying photos (JPG) onto a 2GB SD Card for years.
I now want to transfer these images to another SD Card.
BUT- I get part way through and then it stops with an error message :-
"0x80070052 - cannot create file etc."
I can transfer the total files onto my computer no problem.
BUT then it again will not transfer from the computer to another SD Card. The same message comes up.
On the "properties" of the SD Card, it states some files are Read Only, I cannot find any on the card !!!
BUT it will not let me change the attributes on the card for the file or my computer. I dis-enable the Read Only Box, click Apply and then OK, but nothing happens and it refers back to original, ticked read only.
I have tried to singularly copy or transfer these missing files, but to no avail.
HELP PLEASE
Cheers.
Old 10-07-2011, 11:52 AM   #2
Trollslayer's Avatar
Thanks: Gave 745, Got 932
This sounds like a security issue with the files.
aet3 (10-07-2011)
Old 10-07-2011, 2:05 PM   #3
Any suggestions how I can check and also how to overcome it please ???
Old 11-07-2011, 10:47 AM   #4
Further to my above request for help.
May I ask another appropriate question please:
I have looked on the web for solution to this error. I keep getting a download solution of REG SERVO 1.0.5.1
I have downloaded and run a scan and it found 3017 errors to fix.
When I click "Fix" it asks me to register.
There is no price quoted for how much the activation key costs.
Can anyone help please.
1) Do I need this program to overcome the problems ??
2) How much does it cost ??
Apart from this one copying problem my computer seems to run OK - SO how is there over 3000 errors !!!!!!!!!!!!!!!!!!!!!!!!!!!
HELP
Cheers.
