I'm running some heavy duty software that allows you to be able to mix and scratch videos, like mp4's just like they were on vinyl! (Serato Scratch Live + Video plugin).
My set up as far as computer and outputs are
MBP Laptop OSX 10 (not quite sure .whatever but I try to keep it up to date, I'm on a pc atm)
Scratch Live GUI on the main screen
Video Output on the 2ndry screen a fairly basic monitor with just 1 input and no output.
All I want to do is record the video output on the 2ndry screen... It should be simple shouldn't it?
but the software I'm using doesn't have a video mix record facility...
I've tried using IShowU, which, I think is the mac equivalent to FRAPS? but the problem with this is that my MBP processor seems to be maxed out, even if I use lower quality settings!!!
My 1st thought was to use like a DVD recorder but apparently that's got problems too...
http://www.avforums.com/forums/showt...10#post7639510
there must be better ways than that?
please, I'm not that technical so that is hindering my search efforts.
What would you use to record the input to your monitor if you couldn't use the software on same machine? Baring in mind also that you also need to view this 2ndry output as it's playing and recording.
