Hi chaps,
My Nephew has a PC which I helped him upgrade to make it a better gaming PC. It originally cost only 300 quid or so and hence was quite basic.
Originally it was the following, from memory:
Core i3, first gen at a guess, just over three GHz standard clock
3Gb RAM, 1x1Gb, 1x2Gb (prob running in single channel mode with that unusual config)
Integrated graphics
Obvious stuff like one HD, one DVD writer, card reader, a WIFI receiver in one PCI slot.
300 Watt Bronse certified PSU.
We've made the following mods:
Radeon 6870 (XFX dual fan...
XFX HD 6870 DD cooling 1Gb AMD VGA Card Eyefinity Ready - HD-687A-ZDFC - Scan.co.uk)
And what I thought was a reasonable PSU for the job:
Coolermaster PSU 500W GX Lite
Coolermaster PSU 500W GX Lite- microdirect.co.uk
GFX card use 2 x 6 pin PCI-e power.
Budget was tight, hence the lower spec PSU. Even so, I expected that this PSU would be able to do the job. I would expect 500 watts to be more than enough since the old PSU was 300, and I cannot believe that the new gfx card would use all the additional 200 watts.
As per title, 3DMark Vantage and 11 cause a reboot. Vantage gave a blue screen. 11 gave, if I remember rightly, a reboot with no blue screen.
Minecraft seemed fine. Black OPs was unplayable- 60 plus fps easy at 1080p, but on occasion become a slideshow- usually when entering a new environment (looking at other forums, that could be a problem with the game though). As yet he has no other PC games, thought Crysis 2 might be a good test in the future.
But regarding PCMark reboot, could the PSU be insufficient?
Any advice would be greatly appreciated.
Cheers,
Damo
