Media Server case big enough for 10-15 HDDs?
Old 07-06-2012, 10:10 AM   #1
Thanks: Gave 21, Got 29
I'm about to build a media server to rip and store my entire blu-ray collection of about 400 movies.
I presently have a N36L server with 5x2TB drives and the same amount again in my main PC, as backup.
I now want to whack them all into a new server and do away with the N36L, because it is too slow when trying to convert my movies collection on the fly (particularly with Air Video). It is buffer-central!
I'm looking at the Antec 1200v3, but it's a very old case. Is there anything new out there that will allow me to comfortably fit 10-15 HDDs, with a bit left over for future expansion?
Otherwise, Antec 1200 it is!
Old 07-06-2012, 11:04 AM   #2
HSC HSC is offline
Thanks: Gave 94, Got 120
biggest cases I know of take 10 drives - eg. Fractal Design XL and some Coolermasters
another option would be to convert the 5.25" bays into 3.5"
I added 4 hdd's that way using a fanned 3 bay converter & 4port sata raid card
a similar solution should give you room for 14drives internally (assuming you have enough sata data & power ports as well)
+ more if you mod manually or use external as well
Old 07-06-2012, 11:23 AM   #3
I like the look of that Fractal Design XL. Not that it really matters, because it will be in my AV cupboard, under the stairs so will never been seen.
I like that it holds 10HDDs without the need for any IcyBoxes.
What raid card do you use in your setup?
Old 07-06-2012, 2:07 PM   #4
HSC HSC is offline
I use a Highpoint Rocket 640L 4port card I think
+ board has loads of sata's
but most of my drives are not raided (hardware)
only the stuff I cant lose (personal data etc)
Old 09-06-2012, 7:47 AM   #5
HSC HSC is offline
How about 26 hdd's !!!!
http://www.anandtech.com/show/5967/c...6-35-hdd-slots
Old 09-06-2012, 12:43 PM   #6
Thanks: Gave 0, Got 5
Xigmatek Elysium Interior? wont bust the bank
Old 17-06-2012, 9:20 AM   #7
Thanks: Gave 91, Got 59
I have been looking at that case it is huge
Old 17-06-2012, 9:22 AM   #8
best you can get for the price
