Originally Posted by Desiboy007 OK guys i will use the Y-Adapter for the fans, however can i use both the Low Noise adapters and the y Adapter all together if that makes any sense. So from the fans normal wires to the adapters then both connect into the y-adapter?
Would that work without any hassle? |
First, are your fans PWM (4pin or voltage regulated (3pin)
Second the Y - Adapter question:
If fans are PWM and its a PWM Adapter (4pin sockets for fans and 4pin plug to motherboard) it will work PWM.
PWM fans to 3pin Y.. don't think you can plug fans into Y
3pin fnas on 3pin Y - Adapter (3pin sockets for fan plug and 3pin plug to motherboard) it will not work PWM but will work voltage control.
Low Noise adapters:
Why?
Either way you go... PWM or 3 pin voltage regulation... motherboard can control fan speed.
You will need to monitor system temperatures. I use
Open Hardware Monitor http://openhardwaremonitor.org/
You will also need to install a control program. I use
EasyTune6 (ET6)
GIGABYTE - Support & Downloads - Utility - Motherboard
Go into
bios /
PC health
Scroll to bottom to (they are hidden on first screen)
set:
CPU Smart FAN Control [Enable]
set:
PU Smart FAN Mode [Auto]
Now open
ET6
Click on "
Smart" tab
Click on "
Advanced" tab
Blue ball is low temp / speed setting
Red ball is high temp / speed setting
Set blue at
20% / 20c
Set red at
100% / 50c
(I needed to set high temp @ 50c to get max speed @ 60c)
Click "
Set" button lower right.
You can play with high and low setting to what you find is best for you and your system. Those are just the setting that work best for me. Main thing is to be sure fans ramp up as CPU heats up.
Forgive me if I over-simplified explanation and instructions.
