| Are Noctua fans worth it?
Looking at the two computers, if I were to replace the fans
HTPC
two x NF-S12B ULN (case and for CPU heatsink) £17 each
Gaming rig
Five x NF-P12 PWM (case) £12 each. 19.8dB
Compared to Xilence 12cm fans at £4.66 each 21dB. Is it worth spending the extra?
Unless decide just to go for a single Noctua on the HTPC case fan (that is the loudest) and go for Xilence all round on the gaming rig.
right moved the Noctua 12cm from the gaming rig to the HTPC with the blue speed reduction cable. Quieter than the Antec tri-cool as that made a slight motor drone sound. HTPC is very quiet now.
Just have to decide whether replacing all 12cm case fans plus the Antec 12cm to Xilence. Replacing all with Noctua will be a bit expensive.
