2GB Sandisk Cruzer Enterprise (256 bit Hardware encryption) - £9.99 @ Play.Com
Old 22-09-2009, 12:03 AM   #1
1,062, Level: 7
Points: 1,062, Level: 7 Points: 1,062, Level: 7 Points: 1,062, Level: 7
Thanks: Gave 3, Got 128
Play.com (UK) : SanDisk 2GB Cruzer Enterprise USB Flash Drive : Computing - Free Delivery
Not to be confused with regular flash drives, these feature hardware encryption to keep data safe. I suppose they are meant for business use. If you're saving non-sensitive data a regular flash drive would do.
£9.99 for the 2gb version is really cheap. A quick Google price check lists the cheapest @ £51.24 + delivery for the 2gb. On Play.com the 1gb version is £36.99.
Peridot (23-09-2009)
Old 22-09-2009, 4:03 PM   #2
1,535, Level: 8
Points: 1,535, Level: 8 Points: 1,535, Level: 8 Points: 1,535, Level: 8
Thanks: Gave 8, Got 7
Re: 2GB Sandisk Cruzer Enterprise (256 bit Hardware encryption) - £9.99 @ Play.Com
This is a good buy, I have been wanting one of these for work for a while.
Thank You
Old 23-09-2009, 10:50 AM   #3
Peridot's Avatar
4,944, Level: 16
Points: 4,944, Level: 16 Points: 4,944, Level: 16 Points: 4,944, Level: 16
Thanks: Gave 219, Got 197
This should support OS X too
Old 27-09-2009, 12:15 PM   #4
1,535, Level: 8
The price is now back to £76.92.
Old 27-09-2009, 12:19 PM   #5
Peridot's Avatar
4,944, Level: 16
Just had a dispatch confirmation on mine yesterday - a genuine bargain indeed
Old 27-09-2009, 1:16 PM   #6
4,033, Level: 14
Points: 4,033, Level: 14 Points: 4,033, Level: 14 Points: 4,033, Level: 14
Thanks: Gave 16, Got 5
Ouch, I really wish I had of seen this offer in time!
Old 30-09-2009, 5:52 PM   #7
1,535, Level: 8
Just a quick note for all those that bought one of these usb keys. To make it work properly on a Mac you'll need to update to the latest firmware version 2.5
To get the latest update go to the following site
Secure Business Mobility - SanDisk
Fill in the form and download the file. You have to update the firmware on windows.
Hope this helps, as it wasn't all that easy to find where to obtain an update from.
Peridot (30-09-2009)
Old 30-09-2009, 7:42 PM   #8
Peridot's Avatar
4,944, Level: 16
Mine hasn't arrived yet but that will save me some frustration and time when it does.
