Hi I have the old Sony Vaio VGX XL201 MCE running XP and I have just tracked down a cheap Bluray drive that will allow me to upgrade the DVD drive.
SONY NEC BD-R Blu-Ray SATA DVD Drive Burner BC-5600S on eBay (end time 15-Jul-09 20:02:28 BST).
It is the correct fit front loader. I have read there is a hack for the Cyberlink Power DVD software to change the number of times you can reset the region to 64,000 by a regisrty hack.
Before I order the software can anyone confirm if they have come across this?
Reset CyberLink PowerDVD Blu-Ray Region Code to Free Locking » My Digital Life
It seems to say it will work with any drive. But the post is a few years old and I am not sure if it is still supported in the newer versions. I would be really grateful if someone could confirm if this is the real deal or a load of rubbish.
