Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Other Home Cinema Components > Interconnects, Speaker Cables and Switches > CAT5 Cabling
Latest AVForums Movie Reviews
Sherlock Holmes Blu-ray ReviewClash Of The Titans - Original Motion Picture Soundtrack CD ReviewZombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray Review
Cirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray ReviewClash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Best COD online map and game type lostboybinns Call Of Duty (COD) Xbox 360 16 27-05-2009 9:47 AM
New BT Master Socket extend with Cat5e? ihtspam ISPs and the Internet 10 13-05-2009 4:08 PM
Dolby 5.1 over cat5 Per156GTA Custom Installations and Installers 10 13-05-2009 11:04 AM
Running a pj with Cat5 and hdmi converter? indus Projectors 3 11-05-2009 2:57 PM
help please!!!!! cant type @ sign!!! reevesy Mice, Keyboards, Joysticks and Controllers 4 09-05-2009 4:54 PM
Old 11-05-2009, 5:05 PM   #1 (permalink)
Thanks: Gave 72, Got 64
Different types of Cat5e cable?
I notice there are a few different kinds of Cat5e cable. Could somebody explain what the difference is.
Monitor Audio PL300/PLC 150/RSFX, Audio Research LS17, Quad 909,Quad 99, Quad 99CDP2, Panny 50", Onkyo 875, Sony VPL HW10 pj, Panny BD32 BDP, SVS PCU13, antimode
indus is offline   Reply With Quote
Old 12-05-2009, 10:12 AM   #2 (permalink)
Thanks: Gave 58, Got 127
Re: Different types of Cat5e cable?
Care to link to some of these different kinds?
ben.bayliss is offline   Reply With Quote
Old 12-05-2009, 10:17 AM   #3 (permalink)
Assured Advertiser
LINDY Tech's Avatar
Thanks: Gave 3, Got 49
Firstly,
UTP and FTP or STP
UTP is unshielded, FTP and STP are shielded versions of the cable.
Solid core has a single metal core, where stranded has lots of small cores, typically these are patch cables and solid core is used for wall installations for example.
CAT5/6/7 just refers to the standard, typically CAT6 has a higher twist rate than CAT5 and it rated a lot higher.
It really depends on what you are using them for, if it's a small home setup typically every cable does the same job.
www.lindy.co.uk - AV, home cinema and computer cables & accessories
- AVForums Assured Advertiser, CEDIA Trade Supplier -
LINDY Tech is offline   Reply With Quote
Old 12-05-2009, 10:39 AM   #4 (permalink)
Thanks: Gave 25, Got 85
If you're talking physical see above - if you mean the actual connections - then you can get a Standard or Crossover cable.
> The standard cable connects a Host (PC) to a Network (Switch).
> A crossover (or X-Over) cable connects a Host (PC) to another Host (PC) directly, or a Network (Switch) to another Network (Switch). However, these days most switches have MDI-X ports, which basically means it will work with either type of cable.
PC : i7 920 (@4.0Ghz), 6Gb Corsair DDR3, Gigabyte UD4P, BFG GTX285, 2 x Samsung F1, Corsair 850W TX, CoolerMaster HAF RC932, 24" Iiyama E2407HDS-B1 LCD, LG GGW H20L, XSPC RX360+RX120,4 x Noctua NF-P12, XSPC V3 Delta, EK GTX285, Laing MCP355+XSPC Top = Silence !
RBJTech is offline   Reply With Quote
Old 12-05-2009, 10:48 AM   #5 (permalink)
Assured Advertiser
LINDY Tech's Avatar
I knew I missed something ! Doh
Old 12-05-2009, 2:17 PM   #6 (permalink)
Thanks.
Lindy, mine is for running HD movies on my 1080p pj using a HDMI extender. Which kind do you recommend?
Can I ask another stupid question? Once I've bought the cable and run it, how do I get the connectors on the ends??
Old 12-05-2009, 3:34 PM   #7 (permalink)
Assured Advertiser
LINDY Tech's Avatar
How far do you need the CAT5/6 run?
We have different extenders for different lengths. Longer lengths need two cables.
As for the ends, you need a RJ-45 crimp, with the tool. Simply push in the correct wires to the ends and squeeze
HDMI CAT5e/6 Extender 35m | HDMI | Extenders | Audio / Video | LINDY UK
100m HDMI CAT5e/6 Extender | Video Splitters & Extenders | Sharing, Converting, Extending | LINDY UK
250m HDMI CAT5e/6 Extender | Video Splitters & Extenders | Sharing, Converting, Extending | LINDY UK
70m CAT5e/6 2 Port Switching HDMI Extender | Video Splitters & Extenders | Sharing, Converting, Extending | LINDY UK
RJ-45 Crimp Tool | Tools | Networking | LINDY UK
If you need any more detailed help, drop me a pm or an email via the website
Best Regards
Chris
Old 12-05-2009, 4:08 PM   #8 (permalink)
Chris, the run is only 12m. What kind of Cat5e/6 would you recommend?
Also at the pj end, the power socket is not close by. This would mean the powerlead to the extender would have to be about 4m long, could this be sorted?
Many thanks for your help
Old 12-05-2009, 5:08 PM   #9 (permalink)
If it's only 12m, why not use a proper HDMI cable ?
Old 13-05-2009, 8:14 AM   #10 (permalink)
Assured Advertiser
LINDY Tech's Avatar
Because 12m of HDMI cable is beyond the recommend limit using 1080p
However if that is an option, take a look at this, its an in-line booster.
HDMI Repeater / Extender, 80m | Video Splitters & Extenders | Sharing, Converting, Extending | LINDY UK
I would recommend CAT6 as this is the best with digital extenders.
UTP or FTP/STP, it shouldn't make any difference unless its near high voltage mains etc
Old 13-05-2009, 9:59 AM   #11 (permalink)
Being a cable supplier you obviously know your stuff (but may also have other reasons not just to recommend a longer cable..) but I thought there is no 'maximum' length set in the HDMI specifications. The quality of the cable and it's attenuation will dictate its's maximum length.
To the OP - I run a 10m HDMI cable @ 1080p - about £20 from the net - it works perfectly. I can't see that another 2m is going to suddenly kill the signals - infact the same source sold a 15m one too.
Surely worth trying a 15m cable on sale or return ?
Old 13-05-2009, 10:00 AM   #12 (permalink)
Assured Advertiser
Jamie S's Avatar
Thanks: Gave 5, Got 106
For lengths under 15m, a HDMI cable would be the better option.
As LINDY says, it may be "beyond the recommended limit for 1080p" but that certainly does not mean that 1080p is not achievable via a HDMI cable over 12m.
There are thousands of people out there, (certainly hundreds of our customers) happily using a 15m HDMI cable to watch Full1080p/60hz no problem at all.
A 15m HDMI cable would be a cheaper and easier option.
It is important to note that most projector and display manufacturers are now adding cable EQ (equalization) circuits into their systems. This is a way to counteract the filter effects of a longer cable and help the system to correctly read the digital data. In addition, HDMI 1.3 removed the restrictions on overshoot which prevented the use of pre-emphasis (signal amplification) on source components. Now, sources can improve performance at higher speeds and when using longer cables. As it turns out, most manufacturers are doing exactly this on newer released devices, making long HDMI runs far more achievable than before… Hooray!
We have not had a 15m HDMI cable returned for over 6 months.
I am sure if this thread was in the HDMI cables section of this forum you would get many members giving you the same advice as me.
You can get one of our 15m Pro-2 HDMI cables for £34.99 delivered.
Customer Liaison www.HDCable.co.uk
Buy your HDMI Cable from an Official HDMI Adopter. HDMI over IP is here!
Jamie S is online now   Reply With Quote
RBJTech (13-05-2009)
Old 13-05-2009, 10:48 AM   #13 (permalink)
Assured Advertiser
LINDY Tech's Avatar
I'm not saying every setup will not work with HDMI cable alone, after all we've coupled our Premium Gold HDMI together at DAFT lengths and these still work fine at 1080p
But I doubt everyone would have the same findings, which is why we don't recommend it
Old 13-05-2009, 3:33 PM   #14 (permalink)
sorry I should have given more details.
I already have a 15m hdmi cable that works perfectly. Its a very good quality one from one of the advertisers on this forum.
Problem is now that I've actually come to install it (as opposed to just playing with it) I find it very thick and inflexible. For the install the cable will have to negotiate about 5 full 90 degree bends. This will be very difficult given the stiffness of the cable, and would probably damage it.
Hence I'm investigating the alternative plan of Cat5e/6 with hdmi extender.
To be clear, the powerline for the pj will also run with the cat5e/6 cable(in a plastic conduit) for some of the distance. should I therefore go for the shielded variety? Cat5e or 6
Many thanks
Old 13-05-2009, 3:41 PM   #15 (permalink)
Assured Advertiser
Jamie S's Avatar
OK, in that case and at that distance - unshielded UTP stranded Cat5e or Cat6 cable will be absolutely fine!
cable, cat5e, types
Copyright © 2000-2010 M2N E. & O. E.
