Cat5 or 5e
Old 29-09-2008, 8:50 AM   #1
2,096, Level: 10
Points: 2,096, Level: 10 Points: 2,096, Level: 10 Points: 2,096, Level: 10
Activity: 1.8%
Activity: 1.8% Activity: 1.8% Activity: 1.8%
Thanks: Gave 1, Got 0
Cat5 or 5e
As topic, going to make up the cables for the rears so what do I need? Cat 5 or 5e? Or is there no difference?
Ta!
Old 29-09-2008, 9:23 PM   #2
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Re: Cat5 or 5e
The 'e' stands for extended as in extender frequency range.
Having said that I doubt you would be able to find CAT5 cable as most will have moved over to 'e'.
HTH
V
Old 29-09-2008, 9:51 PM   #3
Assured Advertiser
HDMIHead's Avatar
3,397, Level: 13
Points: 3,397, Level: 13 Points: 3,397, Level: 13 Points: 3,397, Level: 13
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 3, Got 100
Re: Cat5 or 5e
stick with cat5e or even cat6, checkout our blackbox. Good prices
UKHDMI is an Assured Advertiser.
Cablesson ¦ Octava
HDMI Cable - We won the award of the most active company at CEDIA 08.
Old 29-09-2008, 9:57 PM   #4
vex vex is offline
10,368, Level: 24
Activity: 4.2%
Re: Cat5 or 5e
Shame, I thought the OP was talking about the rear channel of his surround sound.
V.
PS What award was that then?
Old 30-09-2008, 6:42 AM   #5
2,096, Level: 10
Activity: 1.8%
Re: Cat5 or 5e
Thats exactly what I am talking about!!
Managed to get some Cat5e lszh for the cost of a pint! Have plaited it up and got it under the floor, just gotta refit the carpet now.
Three plaits is quite a large cable!
