| Re: Would I benefit from Cat5 upgrade?
Although not Radioshak "quality", but nonetheless of that ilk, my son had used some 2.5sq mm flat Sharkwire cable on his B&W 602S3's and had doubled them up for bi-wiring. So notwithstanding the fact that IMO bi-wiring is a waste of time, the only thing one can say about it is that there was alot of copper between the amp (NAD) and the speakers.
When I had bought some cables to test on my system it liberated some Cat5 cables I had made and was using on my kit. So he swapped out the Sharkwire cable for the CAt5. OMG! What a difference, the highs were cleaner but the bass just came to life. It was a huge change.
When I compared (blind A-b switching) the Cat5 to the cables I bought (the Sterling Mamba), on most materials I could not hear any difference. So cat5 does work if you're prepared to have a go at DIY.
EDIT
As an after thought, much depends on your speakers as well. If they're small/lifestyle/satellite type, then Cat5 would be an overkill TBH, as would 14AWG of anything!
