Originally Posted by geothermalcat hi russ, you need to get an rj45 cable tester... http://cgi.ebay.co.uk/LAN-Ethernet-N...ayphotohosting
above is one off ebay, you can pick one up for a few quid. all you do is put one half of the tester on each end of the cable. you will have to terminate the cable ends in order to do this as the testers usually tend to have either coaxial or rj45 connectors, but you can grab a bag of 50 for pennies and a crimper tool (or a punch tool for your patch panel) for a few quid too.
hope this helps
-jon |
Funnily enough i ordered one of the rj45 testers only last night of ebay lol.
Originally Posted by MarkTaylor Can you borrow a continuity tester from someone?
You just need a little voltage on one end and a meter on the other really. |
I never thought of that, poor of me really as im an electrician by trade although rarely deal with cat5e cable.
Sounds like a cracking idea though, 9v battery accross one pair of the cat 5 and just keep testing the corrisponding pairs at the other end until i find 9v there or there abouts on one of the cables.
Thanks for your help lads,
I'm really interested in all aspects of media distribution, once ive learnt a little more about it i may branch out into it a little bit more work wise.
