| Re: Cat5 with baluns - what signal type is used?
That's a good start - it makes it clear what Cat5 cable has going for it. Presumably, then, the simplest baluns will convert audio signals between balanced and unbalanced signals so that the Cat5 cable can be used as balanced signals on twisted pairs.
Does this mean that a pro-audio balanced signal, from a mixing desk for example, will travel down a twisted pair such as those found in a Cat5 cable without modification?
If so, what is the consequence of not including a shield connection, which is normally used on XLR cables to carry balanced sound signals between microphones and mixing desks?
