Sorry, but need to get this off my chest. I've been trying for several days now to get my HDMI over UTP to work, but nothing seems to work. Things I've tried:
* buy a different brand extender
* try with 2x 15m CAT5e cables (factory made connectors)
* re-fitted new connectors on my CAT6 cables
Results:
* most of the time I get a picture, but after a while static shows up, sometimes losing signal, sometimes not but when the static starts, it does not go away
The only thing I've not tried so far is buy 2x factory made CAT6 cables and try these. That might work (I still suspect my CAT6 cables inside the tubing are faulty) but it's again an added costs for those cables with no 100% guarantee for succes.
Only other option I have is buy a 10m long HDMI cable and just connect that whenever the projector is used. Not a clean and nice solution, but one that will work 100%.
My question is: is it possible that my CAT6 cables are at fault? Even after re-fitting new connectors? Or could the cables be affected by some other wiring inside the tubes (there's one power cable inside another tube next to it, and two speaker wires in another one). Also, why don't these extenders work with 15m long factory made CAT5e cables? I know CAT6 is better, but they all advertise 'working' with CAT5.
I'm very disappointed in this technology. I have already spent about 200 euro on two different brands, cables, connectors etc but it never seems to work
ps: I do have 0 problems with 1080i or lower, but as soon as I go up to 1080p, problem arise
