Originally Posted by lapino I can buy two new CAT6 cables in a shop, but I got a feeling these will be straight wired too. I just checked the 2x15m CAT5e cables I bought and these seem to be straight wired (4xpairs next to each other), so maybe that's the reason they don't work.
The current CAT6 cables I'm using have this written on them:
DIGITUS UTP CAT.6 23AWGx4P ISE/IEC 11801 Ed.2 EW S0288 TIE/EIA-568-B.2-11 |
The whole point of CAT5 is that its 'twisted pairs'.. Twisting wires together on a balanced circuit is fundamental when transmitting a signal over a distance.
Due to the way that the RJ45 is wired, for some reason the pairs get split.. SO.. If you wire them one for one, then one 'leg' of the signal will go down one pair and the other will go down another pair.. This will result in them being unbalanced and will affect the ability to transmit high frequencies over long range.
In order to rule this out, you MUST wire the RJ45s correctly... I am not saying it will solve the problem, but since 'twisted pair' is a fundamental requirement for this type of communication, you can't overlook the significance. Whilst wiring them 1 to 1 will result in ELECTRICAL continuity the cable will be incapable of driving high data rates over long distances..
Jon
