Terminal Block or Coupler - best way to extend Cat 6 cables by 2 foot?
Old 10-11-2009, 9:43 AM   #1
3,082, Level: 13
Points: 3,082, Level: 13 Points: 3,082, Level: 13 Points: 3,082, Level: 13
Thanks: Gave 20, Got 0
For one reason or another I have had to relocate my 24 port switch, and a few of my cat 6 cables are a foot or 2 short.
What is the best way to extend the cables? Some googling has suggested using a terminal block for each cable or a cat 6 coupler.
This is for home use (not sure if that is relevant).
Thanks for advice!
