Cat 6 face plates
Old 28-10-2009, 4:40 PM   #1
1,788, Level: 9
Points: 1,788, Level: 9 Points: 1,788, Level: 9 Points: 1,788, Level: 9
Thanks: Gave 13, Got 1
Cat 6 face plates
Is there any advantage to running two cat 6 cables to two single face plates instead of one cat 6 cable to a double face plate.
Old 30-10-2009, 4:33 PM   #2
1,788, Level: 9
Re: Cat 6 face plates
Can I have a show of hands for either YES or NO please......
Old 30-10-2009, 6:10 PM   #3
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
I think 'WHY' might be a better answer.
Why would you want to run a single cable to a double faceplate?
Old 31-10-2009, 5:41 PM   #4
sinewave's Avatar
1,388, Level: 8
Points: 1,388, Level: 8 Points: 1,388, Level: 8 Points: 1,388, Level: 8
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
Thanks: Gave 0, Got 2
Why can't you run 2 x Cat6 cables to one single box with a 2gang faceplate?
Old 01-11-2009, 10:59 AM   #5
5,747, Level: 17
Points: 5,747, Level: 17 Points: 5,747, Level: 17 Points: 5,747, Level: 17
Thanks: Gave 74, Got 24
If you need two connections then you would still need two runs of cable. The double faceplate doesnt act like a splitter of the signal. At the back are two completely seperate connections.
Nathan
