BELKIN or LINDY - Which are the better make of CAT5 and CAT6 cable?
Old 12-10-2009, 10:47 PM   #1
17,401, Level: 31
Points: 17,401, Level: 31 Points: 17,401, Level: 31 Points: 17,401, Level: 31
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 523, Got 135
Old 13-10-2009, 9:13 AM   #2
Assured Advertiser
LINDY Michael's Avatar
1,241, Level: 7
Points: 1,241, Level: 7 Points: 1,241, Level: 7 Points: 1,241, Level: 7
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 4, Got 12
Re: BELKIN or LINDY - Which are the better make of CAT5 and CAT6 cable?
Well, you can probably guess what I'd say!
Seriously though, all our patch cables have a 10 year warranty. We sell tens of thousands of these every year and, honestly, the failure rate is negligible.
Plus, you can contact us directly if you have any queries and speak to an actual technician here in the UK. And, we're here as an assured advertiser, supporting these forums. That's got to be worth something!
MikeO
LINDY Electronics. Computer, Audio / Video and Home Cinema Cables & Accessories. Over 2,500 products in stock.
Established in 1932. ISO 9001 Certified.
www.lindy.co.uk | Follow us on twitter @LINDYUK and Facebook
Old 13-10-2009, 9:22 PM   #3
17,401, Level: 31
Activity: 6.4%
MikeO
Thanks Michael.
Do Lindy do shielded STP CAT6a cables ?
Old 14-10-2009, 7:59 AM   #4
Assured Advertiser
1,241, Level: 7
Activity: 1.7%
Yep. You can find them here.
MikeO
MJeeves (14-10-2009)
Old 14-10-2009, 9:51 PM   #5
17,401, Level: 31
Activity: 6.4%
MikeO
Thanks Mike.
Old 15-10-2009, 8:55 PM   #6
2,189, Level: 10
Points: 2,189, Level: 10 Points: 2,189, Level: 10 Points: 2,189, Level: 10
Thanks: Gave 22, Got 4
In the interest of impatiality (and a little mischief-making!), does anyone have any thoughts on the Belkin cables?
Old 18-10-2009, 3:05 PM   #7
Jamie's Avatar
10,760, Level: 24
Points: 10,760, Level: 24 Points: 10,760, Level: 24 Points: 10,760, Level: 24
Thanks: Gave 93, Got 573
I personally believe theres very little real difference, having said that the only patch cable I've ever had go wrong was a Belkin one. Make of that what you will.
Old 28-10-2009, 3:29 PM   #8
3,457, Level: 13
Points: 3,457, Level: 13 Points: 3,457, Level: 13 Points: 3,457, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 30, Got 95
i almost fell off my chair when i looked at the price of the lindy cables, do youself a favour and get belkin - amazon sell them direct for example:
10 cat 6 £8.15
Belkin Cat6 Snagless UTP Patch Cable 10m: Amazon.co.uk: Electronics & Photo
non-belkin 5m shielded:http://www.amazon.co.uk/5m-Shielded-...743720&sr=1-12
£3.99
if you need cat 5e 7dayshop.com is well priced
Old 29-10-2009, 10:26 AM   #9
Assured Advertiser
1,241, Level: 7
Activity: 1.7%
10 cat 6 £8.15
If you're going to compare branded cables on price, at least make sure you do it like for like. The link I posted earlier was for CAT6a SSTP as per the OP's request.
You can get a LINDY 10m CAT6 UTP for £7.29
10m CAT6 UTP Snagless Network Cable, Black | September | New Products | LINDY UK
MikeO
Old 29-10-2009, 10:57 AM   #10
3,457, Level: 13
Activity: 1.4%
MikeO
fair point so checking amazon:
you can get 10m belkin cat 6 utp for £7.98 see
with free p+p rather than £2.99
check out ebuyer to £3.85 for 10m + £2.58 p and p
http://www.ebuyer.com/product/130700
and also ebuyer for cat6 STP for example belkin 3m £3.75 + £2.58
http://www.ebuyer.com/product/56499
pays your money takes your choice
Old 29-10-2009, 11:44 AM   #11
Assured Advertiser
1,241, Level: 7
Activity: 1.7%
Yep, I agree on that.
Old 29-10-2009, 6:51 PM   #12
17,401, Level: 31
Activity: 6.4%
Thanks guys!
Old 08-11-2009, 5:29 PM   #13
17,401, Level: 31
Activity: 6.4%
MikeO
Do you do these CAT6A STP cables in 2 metre lengths?
Old 09-11-2009, 3:40 PM   #14
Assured Advertiser
1,241, Level: 7
Activity: 1.7%
Apologies for the delay getting back to you. Yes, we do a 2m cable. Unfortunately, due to an oversight it wasn't made visible on the website. The guilty party has been severely reprimanded with a pointy stick .
You can now find it here.
MikeO
MJeeves (09-11-2009)
Old 04-12-2009, 10:05 PM   #15
3,970, Level: 14
Points: 3,970, Level: 14 Points: 3,970, Level: 14 Points: 3,970, Level: 14
Thanks: Gave 226, Got 65
MikeO
Quick question, why is the Cat 5e (Part No 12930) the same price as the Cat 6 (Part No 12937) cables?
Old 07-12-2009, 9:19 AM   #16
Assured Advertiser
1,241, Level: 7
Activity: 1.7%
12937 (The Cat6 cable) is solid core. 12930 (Cat5e) is stranded core. Generally, solid core cable is cheaper than stranded.
For example, our 305m reel of Cat5e UTP solid core is £89.99 as opposed to £114.99 for the equivalent stranded.
Solid core is used in permanent, infrastructure installations inside walls etc. Stranded cable is more flexible and is typically used to make patch cables.
MikeO
Old 08-12-2009, 1:17 PM   #17
Assured Advertiser
Joe Fernand's Avatar
36,535, Level: 46
Points: 36,535, Level: 46 Points: 36,535, Level: 46 Points: 36,535, Level: 46
Activity: 21.3%
Activity: 21.3% Activity: 21.3% Activity: 21.3%
Thanks: Gave 205, Got 1,344
HDMI over CATx Extenders do require a decent grade of CATx cable - what may work in a typical IP infrastructure may well fail in an HDMI infrastructure.
Ensure too that you know which wiring config your HDMI Extenders require - some are TIA-618A, some are TIA-618B, some don't care and some require a straight through connection.
Joe
Old 20-12-2009, 3:08 PM   #18
3,335, Level: 13
Points: 3,335, Level: 13 Points: 3,335, Level: 13 Points: 3,335, Level: 13
Thanks: Gave 40, Got 19
So , Joe , I have one of these in the mail to me at the moment :
Media Factory - Octava HDOCAT, HDMI + Optical 5.1 over CAT5 Extender inc. IR Passthru
which configuration is best for this ?? I was planning to use Cat 6 STP
~M~
Old 21-12-2009, 2:56 PM   #19
3,335, Level: 13
Anyone know the answer to the above question ?
~M~
Old 21-12-2009, 3:19 PM   #20
Assured Advertiser
36,535, Level: 46
Activity: 21.3%
We use this on installs - Product Display: Black Box Network Services
Joe
PS I'm sure Michael at Lindy can sort you out with a suitable alternative!
Manmc (22-12-2009)
