Long time reader first time poster.
I have recently bought and am renovating a house and have run two Cat6 and two coax cables from a central point in my house (the hub) to every TV. I will have (when they are installed) 8 TV's in total ranging from 19" (TileVision) to 50". I have also placed an order for Sky HD which will be getting installed next month. I intend to hook the sky box up with magic eyes running over the coax to the RF2 output in order to change channels so I will have the option of viewing Sky over coax or sky HD over HDMI.
My setup is going to be fairly simple with the TV speakers producing the audio so no suround sound systems or amps.
I've been looking into hdmi Cat6 extenders to allow me to view Sky HD on every TV. I have talked to a few people and read many of the posts in AVForums and other websites in my research. From what information I have gatherd so far I have the following questions:
1. The local AV specialist says that trying to send Sky HD to multiple displays can get quite tricky once the number of displays goes above a few. Apparently this is due to the handshake that takes place within the HDMI protocol i.e. hello I'm a sky box > Hello I'm a 50" plasma that can display 1080i at 60hz > Sky Box - ok I will send you 1080i at 60hz - Crude example but you get the idea. My local specialist says that when hooking up a lot of displays the sky box is trying to handshake with every one of the displays which gets messy (nice techinical term). All that without even mentioning HDCP. So the question is, is it possible to hook Sky HD up to so many displays which all vary in Make, Model, spec etc? Has anyone got a similiar setup up and running with Sky HD and if so what kit did they use?
2. Is it better to take the hdmi output from the sky box and split it (using a HDMI splitter) then hook each "split" hdmi output to a HDMI Cat6 extender or use a device like
THIS one that does the splitting and converting to Cat6 all in one box? As my setup is fairly simple and I'm using magic eyes I don't need digital auio or IR passback over HDMI just the picture and the audio.
3. The only thing that puts me off of the splitter/Cat converter option is that all of these devices that I can find only output onto a single Cat6 cable. I was advised to run two Cat6 cables for this and now that they are run it would make sense to utilise the additional bandwidth available with two. Has anyone got any thoughts on this?
4. One of the TV's is a 19" Tile vision TV in the bathroom with a max resolution of 1440x900 is it worth while deploying the HD solution (Cat6 and coax already in place) to such a small display that can only display 900p which is still more than SD which I think is 480p? This answer will be a matter of opinion but given the cost of a HDMI cat6 sender/receiver is the difference between 480p and 900p on a 19" TV that great?
Appologies if my understanding (i.e. the HDMI handshake, SD resolutions etc) does not add up but I'm no AV expert but want to get the HD piping to every TV right if it is possible at all.
