Cat6 Wallplates
Old 18-09-2009, 8:28 PM   #1
2,461, Level: 11
Points: 2,461, Level: 11 Points: 2,461, Level: 11 Points: 2,461, Level: 11
Cat6 Wallplates
Are there any cat6 wallplates that allow you to use ready made patch leads? Something like a cat6 coupler inside the wallplate. I think these would be much easier for me to install.
thanks
Old 18-09-2009, 9:39 PM   #2
Trollslayer's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Activity: 26.0%
Activity: 26.0% Activity: 26.0% Activity: 26.0%
Thanks: Gave 297, Got 473
Re: Cat6 Wallplates
Tool less outlets? Cable Monkey Tool-less Modules
Not ideal but a lot easier.
Old 18-09-2009, 10:02 PM   #3
2,424, Level: 11
Points: 2,424, Level: 11 Points: 2,424, Level: 11 Points: 2,424, Level: 11
Thanks: Gave 1, Got 10
Re: Cat6 Wallplates
An alternative:
Cat6 coupler type keystone jacks:
Cat 6 Coupler Jacks
They have a RJ45 connector on both sides, so you can use ready made cables. No special connections are neccessary.
Then, you snap them into a wall plate such as these:
Smooth Face Keystone
