Cat6 - external grade cable - where from?
Old 16-09-2009, 9:01 AM   #1
3,988, Level: 14
Points: 3,988, Level: 14 Points: 3,988, Level: 14 Points: 3,988, Level: 14
Thanks: Gave 42, Got 3
Hi all
Anyone give me tips as to where I can get external grade Cat6 cable from? I've been searching around for it, but so far not had much luck.
Need 2 x 21 metres.
Old 06-10-2009, 7:10 PM   #2
6,071, Level: 18
Points: 6,071, Level: 18 Points: 6,071, Level: 18 Points: 6,071, Level: 18
Thanks: Gave 2, Got 6
Re: Cat6 - external grade cable - where from?
I just bought some off ebay.
It was £5/5m so you would need to buy 45m quantity of 9.
The seller was Mr...Telephone or do a search for external cat6.
Hope this helps.
Clive.
Old 28-10-2009, 3:34 PM   #3
3,457, Level: 13
Points: 3,457, Level: 13 Points: 3,457, Level: 13 Points: 3,457, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 30, Got 95
i would have thought get get the normal stuff and protect in conduit - much easier for any upgrades at a later date and protected from uv
