Phono audio over cat5e
Old 17-08-2009, 1:20 PM   #1
4,615, Level: 16
Points: 4,615, Level: 16 Points: 4,615, Level: 16 Points: 4,615, Level: 16
Thanks: Gave 2, Got 9
Will phono audio over cat5 work?
I don't need it to be top quality, its only for TV audio to send upstairs to another tv (video is going be coaxial). so as long as there's no loud crackling or hissing sounds then i can use it.
Old 17-08-2009, 1:26 PM   #2
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
Re: Phono audio over cat5e
Biggest problem is likely to be hum, particularly if the cat5 runs near mains for any length.
A balun at either end should help dramatically.
regards
Brian
Old 17-08-2009, 1:49 PM   #3
4,615, Level: 16
I thought of those, but because the lengths I'm running are only around 20-25m, it'd be cheaper to just buy the phono cables.
Was just seeing if the even cheaper option of running cat5 would work.
Old 17-08-2009, 1:50 PM   #4
Trollslayer's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Activity: 26.0%
Activity: 26.0% Activity: 26.0% Activity: 26.0%
Thanks: Gave 297, Got 473
Cool, I've used more expensive ones at work.
I would be careful about the bass response though, baluns aren't too good for that.
Old 17-08-2009, 1:53 PM   #5
mossym's Avatar
Location: You'd get your feet wet getting here, but the Guinness is worth it...
24,850, Level: 38
Points: 24,850, Level: 38 Points: 24,850, Level: 38 Points: 24,850, Level: 38
Activity: 11.8%
Activity: 11.8% Activity: 11.8% Activity: 11.8%
Thanks: Gave 598, Got 1,310
can you not send the audio over the coax as well?
Old 17-08-2009, 2:07 PM   #6
8,177, Level: 21
Points: 8,177, Level: 21 Points: 8,177, Level: 21 Points: 8,177, Level: 21
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 72, Got 547
Originally Posted by sswats View Post
...20-25m...
I've run analogue voice over 100 of meters on cat5e, no problem. Having travelled several 1000m to get to your home, a few extra tens of meters won't worry it.
Old 28-08-2009, 7:52 AM   #7
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Separating the video and audio over separate runs is fine as long as you have the ability to make any required adjustment to keep the signals in-sync once you bring them back together at the TV/HiFi.
If you have video and audio over coaxial to the TV would it not be simpler to output stereo audio from the TV to a local Amp - most TV's have at least one audio Output.
Joe
