Which Splitter & HDMI Cat5 Balun
Old 21-07-2009, 10:24 AM   #1
4,402, Level: 15
Points: 4,402, Level: 15 Points: 4,402, Level: 15 Points: 4,402, Level: 15
I need to purchase a HDMI Splitter and cat5 transmitter balun.
I want to make sure that I get the correct ones that will do the job and not degrade the HD picture to the second TV.
Kit list as follows;
Panasonic G10 - buying today
Sky HD - Amstrad box (new replaced both that doesn't have component output hence the need for splitter / balun )
Ideally my TViX box.
Ideally PS3.
I have run 3 cat5 cables to the other TV which is around 8mtrs away.
Suggestions greatly received as always.
Matt
Old 21-07-2009, 10:41 AM   #2
Assured Advertiser
Jamie S's Avatar
3,359, Level: 13
Points: 3,359, Level: 13 Points: 3,359, Level: 13 Points: 3,359, Level: 13
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 40, Got 177
Re: Which Splitter & HDMI Cat5 Balun
For a run of 8m, you could use a HDMI cable instead of Cat5.
Is there a particular reason why you are choosing Cat5 over a HDMI cable in this instance?
It would work out cheaper and less hassle really.
Customer Service Team @ HD Cable Ltd
Old 21-07-2009, 10:49 AM   #3
4,402, Level: 15
Purley for cabling reasons, my house is having the finishing touches put to it and as such skirting boards were not down nor the floor tiled so routed cat5 round between tiles and wall.
Originally I was just going to put component connectors on each end but with the HD box being changed this is no longer a option.
Old 21-07-2009, 11:02 AM   #4
Assured Advertiser
Jamie S's Avatar
3,359, Level: 13
Activity: 8.0%
8m is too short a distance for our models of HDMI over Cat5/6 extenders, however I believe Joe's from The Media Factory will work over a short distance.
//www.tmfsolutions.co.uk/
Joe Fernand (21-07-2009)
Old 21-07-2009, 1:18 PM   #5
4,402, Level: 15
Thank you for your help.
Joe, do you have any suggestions for my kit as listed above please?
Matt
Old 21-07-2009, 2:46 PM   #6
Assured Advertiser
Joe Fernand's Avatar
36,531, Level: 46
Points: 36,531, Level: 46 Points: 36,531, Level: 46 Points: 36,531, Level: 46
Activity: 20.9%
Activity: 20.9% Activity: 20.9% Activity: 20.9%
Thanks: Gave 205, Got 1,344
Hello
You can combine the Octava HDDA12-UK (Media Factory - Octava HDDA12-UK, 1x2 HDMI distribution amp.) plus HDMICAT-UK (Media Factory - Octava HDMICAT-UK, HDMI over CAT5 extender) or HDOCAT-UK (Media Factory - Octava HDOCAT, HDMI + Optical 5.1 over CAT5 Extender inc. IR Passthru) to achieve what you require.
The HDMICAT and HDOCAT will work with short CAT5/6 cable runs - I have a 2m CAT5e run in the test rig now running Freesat at 1080i50.
The HDOCAT unit gives you the option of IR over your CAT5 cables.
Is there an AV Amp anywhere in your system?
Joe
Old 21-07-2009, 4:06 PM   #7
4,402, Level: 15
Thanks Joe, I guess the 2nd cat5 option is if there is a optical sound source at the other end. In my case no I will just be using the speaker in the panasonic plasma.
I have run 3 shielded cat5 cables.
I do have a amp, that I'm wanting to upgrade to a HDMI capable one. Currently it is a Yamaha DSP AX750SE.
Old 21-07-2009, 4:41 PM   #8
21,436, Level: 35
Points: 21,436, Level: 35 Points: 21,436, Level: 35 Points: 21,436, Level: 35
Activity: 5.8%
Activity: 5.8% Activity: 5.8% Activity: 5.8%
Thanks: Gave 239, Got 101
I can help with the splitter if that's still on the agenda?
I've just bought two from neet cables (on amazon and flea) and they work perfectly and are the size of a small box of fags.
The service from the company was top notch. They cost £35 delivered.
One of them is connected to a 15m run of hdmi cable to a 1080p pj, no problems at all.
I would recommend them 100%
Old 21-07-2009, 7:18 PM   #9
20,829, Level: 35
Points: 20,829, Level: 35 Points: 20,829, Level: 35 Points: 20,829, Level: 35
Thanks: Gave 49, Got 709
Do note though that the OP only has an 8m cable run and that is a problem for some baluns so their ability to work at that length needs to be checked.
Old 21-07-2009, 7:33 PM   #10
Assured Advertiser
36,531, Level: 46
Activity: 20.9%
Hello MattyHerts
The key advantage (for some) of the HDOCAT is the ability to carry HDMI to the Display + IR back to the Source kit over the two CAT5 cables.
Joe
Old 02-09-2009, 6:17 PM   #11
8,396, Level: 21
Points: 8,396, Level: 21 Points: 8,396, Level: 21 Points: 8,396, Level: 21
Thanks: Gave 1, Got 24
Which ones DO work over 8m (got a problem with the ones from neetcables here - they seem to break my Optoma projector)
Old 03-09-2009, 7:36 AM   #12
Assured Advertiser
36,531, Level: 46
Activity: 20.9%
Hello lapino
The Octava units (Media Factory - Octava HDMICAT-UK, HDMI over CAT5 extender and Media Factory - Octava HDOCAT, HDMI + Optical 5.1 over CAT5 Extender inc. IR Passthru) will work at 8m.
Joe
Old 03-09-2009, 2:04 PM   #13
4,941, Level: 16
Points: 4,941, Level: 16 Points: 4,941, Level: 16 Points: 4,941, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 31, Got 26
Hope you don't mind me asking a question on your thread
Jamie and Joe, Do your HDMI to cat5/6 extenders work through AV Receivers? I would like to extend my SkyHD from lounge to HC room (about 20m max) but at the HC room end I have an AV Receiver which feeds my PJ so this end will need to connect to my Denon 3808 AV Receiver.
Any known problems?
thanks.
Old 03-09-2009, 2:23 PM   #14
Assured Advertiser
Jamie S's Avatar
3,359, Level: 13
Activity: 8.0%
Not at 20m I shouldn't think there would be any problems.
In theory, connecting via an extender should be exactly the same as if you were connecting a 1m HDMI cable direct.
However, in practice it doesn't always work out like that, especially with AV receivers. The EDID and HDCP data on a HDMI signal is very fragile, any imperfection will not be tolerated by the AV receiver.
As long as you are using good quality Cat6 cabling and well terminated connectors I would not foresee a problem. The signal should be rock solid for you.
welshy (03-09-2009)
Old 04-09-2009, 8:03 AM   #15
Assured Advertiser
36,531, Level: 46
Activity: 20.9%
I keep various AV Amps here for testing connectivity configurations, problems and pre production samples.
I have an Onkyo TX-SR606 in the rack and am currently watching Freesat over a 40m dual CAT5 connection using a set of the Octava HDOCAT-UK extenders.
With the HDOCAT-UK I have full IR control of the Freesat and Onkyo AV Amp over the CAT5 connection.
If I follow correctly you are looking to first split the SKY HD output then extend one run over 20m of CAT5 to feed the AV Amp and then output to the Projector! That's a 'slightly' more torturous signal path but again something we know we can achieve.
Another advantage of the Octava HDOCAT-UK unit is that we provide HDMI + Optical + the IR Passthru channel so we can get the DD optical signal from the SKY HD box to your amp along with the HDMI signal.
Joe
welshy (07-09-2009)
