Cat5e baluns and sky hd- no sound!!
Old 22-05-2009, 11:18 AM   #1
Have set my Baluns up, with 3om cat5e cable. The picture is very shaky when it is just run from the baluns, however if i then split the signal using a powered hdmi splitter the picture quality is perfect, however there is not any sound, unless i then add another splitter to the other end of the run. Can someone please advise? thanks
Old 22-05-2009, 12:48 PM   #2
Assured Advertiser
LINDY Chris's Avatar
2,019, Level: 10
Points: 2,019, Level: 10 Points: 2,019, Level: 10 Points: 2,019, Level: 10
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 4, Got 63
Re: Cat5e baluns and sky hd- no sound!!
To be honest it sounds like the baluns are not up to the job.
Which ones have you purchased?
Sound normally drops off before the picture does when the bandwidth /signal is low.
I could recommend one that should work for you if you wish.
Chris
LINDY Electronics. Computer, Audio / Video and Home Cinema Cables & Accessories. Over 2,500 products in stock.
Established in 1932. ISO 9001 Certified.
www.lindy.co.uk | Follow us on twitter @LINDYUK and Facebook
