Originally Posted by RobD79
Hi all,
I have had a Kenwood 5220BT installed and it is a fantastic unit. Unfortunately, I am running into a bit of block when it comes to uploading custom POIs (i.e. speed cameras) to the unit. Can anyone here tell me how I can do it and what I need?
Many thanks in advance,
Rob
You'll need Garmin's POI Loader utility to convert the POIs into a compatible format.
http://www8.garmin.com/products/poiloader/
The way I did it, on an 8220BT (the same I imagine) was:
- Copy all the POIs I wanted to upload (in CSV format) to separate directory
- Insert an SD Card into the PC
- Start POI Loader and set the destination as a "Garmin Device"
- Select the drive letter used by the SD card as the target
- Select all the POIs to add and let the Express wizard run
- Then the data is added in the format required in the correct folder structure to the card
- With NAV running insert the SD card and it should copy the POIs and present a confirmation message
I did have an initial issue with the first SD card, said it was successful but nothing in the menu. Second card and attempt and worked fine.
Good luck!
