3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > In Car Entertainment (ICE)
Today's price checkPowered by
Sony XM-ZR 604
i-Station Traveller for iPhone (Euro Version)
JVC KD-R801
Blaupunkt PCA 465
JVC KD-R301
Sony XM-ZR 604
i-Station Traveller for iPhone (Euro ...
JVC KD-R801
Blaupunkt PCA 465
KENWOOD KFC-E1362C Speakers
JVC KD-R401E
Kenwood KAC-6203
FUSION EN-FR4620 10 x 15 cm 120W 2-Wa...
Pioneer DEH-P4100SD
 More...Prices updated November 8th at 9:30pm and include delivery.
Alpine IDA-X100 installed (with video)..... welshchris In Car Entertainment (ICE) 28 01-11-2008 10:40 AM
Alpine X001/X100 APN Converter stroppygoblin In Car Entertainment (ICE) 9 02-05-2008 1:21 AM
Alpine iDA-X100 Availability knobby01 In Car Entertainment (ICE) 6 06-04-2008 6:35 PM
Alpine iDA-X001 w/ Alpine TUA-T500HD HD Tuner. IsLNdbOi In Car Entertainment (ICE) 0 02-11-2007 9:27 AM
DV Storm Vs RT.X100 colinrmorris Camcorders and Video Editing 1 09-08-2002 8:41 PM
Old 07-05-2008, 4:46 AM   #1 (permalink)
Thanks: Gave 0, Got 2
Notes on the Alpine iDA-X100
Hello all, I’m a complete noob here. I hope my first post doesn’t ramble too badly! I did a fair amount of reading on this forum and many others regarding the Alpine iDA-X100 both before and after I bought one. I thought Id share my observations and issues with the group.
First off, I’ve owned the iDA-X100 for a little over four weeks now. The head unit is solid and functional. The overall sound quality isn't on par with the higher end CDA-7894 that was in the car before. This is mostly due to the fact that the wizards of Alpine have relegated the finer audio controls to the IMPRINT module (available at extra cost naturally) which were built into the 7894. Aside from some minor nits such as the volume control and the glare on the LCD Screen, I’ve found the unit to be an admirable replacement for my older CD/MP3 player. At the same time I purchased myself a 160MB iPod classic (6th generation).
Installation was clean, all the connections are made into the back of the head unit and the only wire dongle is for the power. Everything else plugs into jacks or sockets. It’s a high power unit so your best bet is to run a dedicated line to the battery. I lucked out in that my car came from the factory with a high powered stereo so the fused lines to the factory head unit were AWG12 with a 20A dedicated fuse. The USB Cable attaches to the rear of the head unit as well although it has a screw in thumb screw to keep it attached. The USB lead is long enough to reach to the glove box or center console of most cars but not nearly long enough to reach to the rear seat or trunk of most mid sized US cars. Luckily, the wiring harness was identical to my older CDA-7894 so changing the wiring harness wasn’t necessary to upgrade to the iDA-X100. This saved me over an hour of cutting, stripping and applying heat shrink to the speaker and accessory wires. A word of advice, if your car has dash dimmer controls, Id recommend hooking up the illumination lead of the head unit. Having the head unit dim with the rest of the dash lights definitely separates your install from the rest.
Operation with the iPod classic is fairly straight forward, when you connect the USB dock cable provided with the head unit into the iPod, the unit displays an Alpine splash screen and disables the iPod controls. Everything is controlled through the round jogger control and the center select button. There are several different search modes available depending on how you set up the options on your head unit. The manual sorts them out fairly well. It will pay off when your driving if you spend some time with the jogger control while parked so you can find your songs quickly and easily. Otherwise, frustration, cursing and potentially an accident will result. Its not quite as intuitive as the Apple, but not bad. Also pay attention to how Alpine lets you search the folder or several folders by pushing down on the outer ring of the jogger and twisting slightly left or right. This also works on play-lists.
As a side note, you can use a massive hard drive hooked up to an IDE/SATA to USB dongle. As long as the dongle is USB2.0 compatible, the Alpine will recognize the drive as storage. The downside is that the head unit will start playing at the first song on the drive every time and will not remember the song you were playing when you turned the car off. Even if you wire the drive to run while the car is off, the head unit starts from zero every time it searches the drive. USB Thumb drives operate in the same way. This is a major bummer since 1TB drives are available in the US for less than $250. Also, even though the Creative Labs Zen Vision has a docking port, this head unit will not control those MP3 Players unless you enable disk mode on the player. Then the head unit accesses the Zen the same way the basic hard drive works. Again a bummer since the Zen players will handle WMA files as well as WAV and MP3 Most ratings put the WMA format slightly above the AAC format used by the iPod in terms of musicality and tonal quality. Honestly, I can’t hear the difference between WAV, WMA and the Apple Lossless compression, but I can hear a marked difference between any MP3 and the above mentioned compressors.
Now for the fun parts. I noticed early on (the first day I drove the car to work) that the iPod classic will randomly stop playing music. The display will stop counting the time on the song and the audio will stop. After several seconds, the audio will resume and everything will be as it should on the display. This happens several times during my commute (70 minutes) and has no apparent pattern or cause. This occurs with iPod Classic software 1.03 as well as 1.1.1 and 1.1.2 The only visible difference between the three versions is that now the iPod backlight turns off after the time out period where as before it would stay on as long as the iPod was connected to the head unit. At first I considered that the hard drive was skipping as the suspension in my car is fairly stiff. I orientated the iPod horizontally, vertically and at 15 degree increments between the two, both face up and face down. Orientation made no change in the frequency of failure. I also ran the head unit and iPod with the car standing still. Again, the failure was present with approximately the same frequency as before. I did have one error free drive the other day and the only physical change I can think of is that it was cold outside (mid 50’s) versus the mid 60’s during the other drives. It was also overcast and there was no sun shining on the iPod as it sat in the passenger’s seat. I’ve yet to fully test this theory, but I don’t have high hopes based on my other observations.
The Alpine manual mentions that iTunes versions higher than 7.4.3.1 are not tested with the head unit. I downgraded my iTunes version to 7.4.3.1 and re-synced my iPod. The problem was still there and with the same frequency. Since there was no difference, I went back to iTunes version 7.6.2.9.
Thinking that the iPod was having problems keeping up with the data stream caused by a massive library ripped using Apple lossless compression, I re-ripped several playlists down to 128kbps MP3, 128kbps AAC, and even WAV encoder with no positive reactions.
Doing some research on the internet, I found this type of problem quite prevalent in the earlier models of the iPod Classic and suspect it’s a firmware/hardware/software problem yet to be sorted out by Apple. Out of frustration, I went and got the 32GB iPod Touch. This unit runs software version 1.1.4 and does not exhibit the problem that the iPod Classic has. It has run for hours on end without failure, it runs in direct sunlight (hot) and even sitting right under the A/C vent. It also responds much quicker to user input which is understandable given this unit does not employ a hard drive. The down side is that the touch will never hold my media collection in lossless format.
Based on my experience thus far, I would highly recommend this head unit. While its not the cheapest head unit available from Alpine that will allow you to play compressed music and control an iPod, it has some nice features that made it worth the $349.99 here in the USA. I would not recommend using the iPod classic (either the 80GB or 160GB versions) as there seems to be some issues that Apple needs to work out still.
mleboeuf is offline   Reply With Quote
Supernaught (24-07-2008), tritoch (10-05-2008)
Old 08-05-2008, 9:23 PM   #2 (permalink)
Thanks: Gave 2, Got 0
Re: Notes on the Alpine iDA-X100
Very informative post
Can the artwork be turned off in the USB mode do you know as it takes up valuable space on the screen
tommyturbo is offline   Reply With Quote
Old 10-05-2008, 12:14 PM   #3 (permalink)
Thanks: Gave 2, Got 2
Hiya, I am looking into getting an iDA-X300/iDA-X200/iDA-X100/iDA-X001 and just wanted to say thanks for the information.
I also have an idea as to why the pause occurs. After scouting the internet, I've noticed that this problem seems to occur with the larger iPod's (in terms of disk space).
Thus, the 160GB would give the worst problems as file indexing and library building takes much longer than would on an 80GB.
Anyway, thanks for the information.
Mo.
tritoch is offline   Reply With Quote
Old 07-07-2008, 9:54 AM   #4 (permalink)
Unhappy Re: Notes on the Alpine iDA-X100
Thanks for that very informative review. Sounds like the 6th Gen iPod compatibility issues are all across the board! My iDA-X100 won't see my 160G through USB at all. I had to buy the "Full Speed" cable for it to work. Another problem is it won't do the "page skip" or "percent skip" as it's supposed to. I have to sit there and skip through album by album. Its a big pain in the...! I read somewhere else that Alpine may do a firmware update, so I'm going to call them and find out if that's true or not or even possible.
Even with all the problems, I'm most likely going to keep the iDA-X100 because of the "Imprint" feature. I do live sound for a living, so having time alignment and parametric or graphic EQ is a must for me. This unit is replacing my old Clarion with the add on module similar to Alpine's Imprint module.
If I get my old 4th Gen iPod working again (replacing it's burnt out motherboard), I may leave it in the trunk full time. That is...if there aren't more compatibility issues with 4th Gen's, sheesh!
masayoshi is offline   Reply With Quote
Old 07-07-2008, 10:46 AM   #5 (permalink)
Thanks: Gave 89, Got 111
This is a very interesting thread. I have had an X100 for a few weeks now, and it has been near faultless with my 160G Ipod Classic. On a couple of occasions, I have started the engine and the X100 has come up with 'Error', and I have had to disconnect the Ipod and start again. Apart from that it has been perfect.
masayoshi - I don't think that the percentage skip function works unless you have the Ipod connected by USB.
daveb975 is offline   Reply With Quote
Old 09-07-2008, 7:24 PM   #6 (permalink)
Thanks: Gave 5, Got 8
1) Do these Alpine units charge the Ipod as you are using either the USB or the fast data cable?
2) Do you have to turn the Ipod on/off manually?
3) Can you plug an active subwoofer into the back?
TIA
jimnorth is offline   Reply With Quote
Old 09-07-2008, 8:53 PM   #7 (permalink)
TIA
1) They do charge the iPod through USB, not sure about 'full speed'
2) No
3) Yes, the X100 has 3 pre-outs, and you can control the sub independently directly from the HU.
Old 10-07-2008, 5:29 PM   #8 (permalink)
2) No
Thanks for that....much appreciated.
Old 12-07-2008, 3:31 PM   #9 (permalink)
I just bought the ida-x100 and a ipod classic 80 gb and the headunit does not work with it. Its works fine with flash memory. I bought this unit so that I could use the playlist feature and random shuffle. But I'm still within my return timelimit so its going back to the store. They should have done more test to make sure Apple cant come out with an update that would disable a very important feature.
I will try and call alpine to see if they have a fix for this. If not they just lost a customer.
twinbeam is offline   Reply With Quote
Old 23-07-2008, 10:35 PM   #10 (permalink)
Update...I went back to the owners manual a few times and finally figured out how to get to the "percent skip" feature, so its definitely available using the "Full Speed" cable. Oh, and yes this cable also charges the iPod. Haven't had time to call Alpine about the firmware update question yet.
Old 24-07-2008, 7:34 AM   #11 (permalink)
Thanks: Gave 9, Got 15
2) No
Yes it does turn the iPOd on and off you just need to make sure you have a switched live to the back of the stereo.
If you just turn the stereo off yourself it doesn't turn it off but if the unit is powered down by the switched live it will.
Can seem to get % search to work I don't appear to have an option to change the search function and am stuck with page skip
descb600f is offline   Reply With Quote
Old 03-08-2008, 6:00 AM   #12 (permalink)
Chiming in that I have the same pausing issue with my 8gb 3rd gen Nano. However there was an ipod update released today which I have applied so I will test it out this week.
Im also clearing a lot of crap off my ipod so we will see how that affects it (library building)
Does anyone else encounter a half second delay when skipping tracks? I press skip, and it takes half a second for it (roughly) to change tracks.
Varvs is offline   Reply With Quote
Old 06-08-2008, 11:22 AM   #13 (permalink)
Yep I have seen it take a spit second to get a skip.
Im not sure if it's to do with it accessing the artwork which is slowing it down
Old 07-08-2008, 6:02 PM   #14 (permalink)
Has anyone managed to get the radio presets to show the station name rather than the frequency a little annoying as you have to remember what preset is what.
Hoping someone can help des
Old 08-08-2008, 10:48 PM   #15 (permalink)
Thanks: Gave 17, Got 29
I previously had the Alpine CDE-9850Ri and thought that the X100 would be an upgrade, but I have noticed a marked difference in sound quality. While I cant knock the X100 for clarity, mids and treble, there seems to be almost no bass until I turn the bass level up to +4 or 5, which then gives me a dull bass mush, rather than a punchy solid bass that a had with the older unit.
I use the Chili Peppers for all my audio tests and the diffrence stands out a mile. I really like the X100 and Im thinking of shelling out for a basic sub + amp to improve matters.
Does anyone in the know think the Imprint unit would be more beneficial?
Thanks...
Supernaught is offline   Reply With Quote
alpine, idax100, notes
