dab in a ford
Old 18-12-2007, 4:39 PM   #1
5,991, Level: 18
Points: 5,991, Level: 18 Points: 5,991, Level: 18 Points: 5,991, Level: 18
Thanks: Gave 3, Got 3
dab in a ford
has anyone put a dab radio into a ford,just bought a new focus and would like to fit my jvc dab but cant find a suitable aerial(dont want a stick on windscreen effort or have to redrill the roof)
Old 22-12-2007, 12:15 PM   #2
4,602, Level: 16
Points: 4,602, Level: 16 Points: 4,602, Level: 16 Points: 4,602, Level: 16
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 14, Got 134
Re: dab in a ford
The stick on windscreen aerials are a joke. Use a glass mount such as Panorama
but make sure you stick it on when the weather is warm, should last for years, if cold when applied will probably fall off in a few months.
Old 22-12-2007, 9:11 PM   #3
1,857, Level: 10
Points: 1,857, Level: 10 Points: 1,857, Level: 10 Points: 1,857, Level: 10
Thanks: Gave 9, Got 1
Re: dab in a ford
Bosch do a 3 way roof antenna (3 ways being am/fm/dab).
It would replace the roof mount 'bee sting' type , but i think Ford's have a roof antenna mounted at the front of the roof. I recall it was a great performer (back in 2001). SMA type connector I think??.
Rob.
Old 24-12-2007, 6:55 PM   #4
darren68uk's Avatar
5,228, Level: 17
Points: 5,228, Level: 17 Points: 5,228, Level: 17 Points: 5,228, Level: 17
Thanks: Gave 153, Got 75
Re: dab in a ford
ive just fitted one to my A4 they cant have holes drilled cos of the anti corrosion warranty,,,
cheapest place is bluespot and with them you get everything, and that is the panorama one
http://www.bluespot.co.uk/stock/dab_glass.asp
but they also do the all in one i think and from what ive heard if you can replace your exsisting one with the fm/dab jobby thats the best as apparently the roof is utilised as a grounding plate(whatever that means) but gives you the best reception, but i travel wells in somerset to chippenham to work and my glass mount is not bad, hope that all helps
Old 24-12-2007, 7:06 PM   #5
3,666, Level: 14
Points: 3,666, Level: 14 Points: 3,666, Level: 14 Points: 3,666, Level: 14
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 218, Got 388
Re: dab in a ford
I've had a Blaupunkt DAB radio in my Mondeo for at least 3 years now. I use one of the stick-on aerials listed in the previous post and it works great. I've never had to re-stick it and its been through all sorts of extremes of weather. Reception is very good, even in rural Devon where I live. There's one bit on the M5 nearby where it loses signal because of a hill, but then AM cuts out there too, to be fair.
Old 31-12-2007, 11:50 AM   #6
basherontour
Posts: n/a
Re: dab in a ford
I can concur totally with Wild Weasel, in that I replaced my Ford unit with a Blaupunkt DAB unit and I too had an aerial fitted to my side rear window (Focus estate) that has never come unstuck.
Powered by
 Latest popular product prices
Sony XS-F1337SE 5 inch 13cm 3-Wa...
1 price
 £28.28 Click to show/hide the offers
1 price
1 price
IN PHASE Audio In Phase XT42II S...
1 price
 £35.96 Click to show/hide the offers
1 price
1 price
Excalibur X500.2
1 price
 £39.99 Click to show/hide the offers
Excalibur X500.2
1 price
 Updated February 10th at 10:30am. Prices include delivery.
